Page 20 of 47 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 467
Thread: Robot SMASH!!
  1. #191
    Guest
    Really Frank I thought you were right, it makes itm uch easier for you if I say whos fighting next. I would have always done it, but could never remember!If I cant remember now I just edit the post, as Joey knows!
    Heat Semi-Finals will be written soon, maybe tonight or tommorrow
  2. #192
    Guest
    Heat Semi-Final 3/16:
    Shadow Zone Returns v All Scoop...
    Shadow Zone had a good round in the eliminators, defeating Fire and Ice. But Steven could be a tougher opponent, not so much the design that Shadow Zone can fight well...Let see how it goes..
    All Scoop is short for... Click on an archive, Im never typing it again!!
    In the eliminator it pitted an old hand, Back to Rock III and is now a hot favourite to get the heat!
    Booth 1: Kody Kunz
    Booth 2: Steven McGregor
    5,4,3,2,1, ELIMINATE!
    Shadow Zone seems to be lining up a flipper attack rather than a ramming onslaught with the front scoop, as Kody has turned around and seems to be trying to get around Steves rear end!
    But All Scoop is wiser and turns to meet the attack, meeting Shadow Zone head on! Steven hits Kodys flipping arm with his axe, and pushes it across the arena into the pit release tyre!
    To get Steven away Kody fires the arm and flings the axe off, before turning around and getting under the side of All Scoop, ramming it into the corner! The spike turns Kody over and Steven comes in on the attack, hitting with the axe again and lifting with the scoop! Steven carries Shadow Zone toward the side wall and tries to dump it out! Shadow Zone fires the flipper in desparation, but to no avail as Steven has already let go!
    THE CAMERA TRACKS ARE DAMAGED!
    Kodys gone and has damaged my camera
    All Scoop goes through to the heat final!
    Coming Next:
    D.V.D v Supreme Glory Omega
    And a question I want to ask:
    Would this 64 robot tournament classify as a major?
  3. #193
    Yep, I dont really understand why its like that but I believe tournaments with more than 40 robots are major...
  4. #194
  5. #195
    Guest
    Heat Semi-Final 4/16:
    D.V.D knocked Iron Awe 5 OOTA in round one, proving the power of its drum. Daniels lexan armour may prove no match for a weapon of this calibre, but will Pauls wheels hold up to that axe?
    Supreme Glory Omega is a seasoned veteran of my tournaments. It started badly in the eliminator round, getting shoved around by Dead Horse Beater. But eventually Franks base armour proved too weak and the axe died after the co2 canister was destroyed.
    Booth 1: Paul Cuomo
    Booth 2: Daniel Stickler
    5,4,3,2,1, DECAPITATE!
    D.V.D starts spinning up, but in comes SGO and slams it into the arena wall! Daniel bashes D.V.D with the axe, and Paul keeps spinning up the drum as he struggles to get away. Finally he breaks free and runs a short way before turning to face SGO, which starts quaking and scarpers! Paul comes in from behind and hits SGO with the drum! A rear panel now has a nice gash in it and SGO is flipped upon impact! Daniel quickly self-rights and comes back on the attack, bashing D.V.D once again with that powerful axe! D.V.D keeps spinning up that drum, but when he attacks he finds he cant, because Daniel has got his axe stuck in a wheel rut and is holding D.V.D at arms length! Paul struggles, but Daniel pushes him across the arena and into the pit release tyre! He tries to pull Paul towards the chasm, but D.V.D gets free and slams into Supreme Glory Omega hard!
    CRASH!
    The already damaged panel flies off completely and SGO turns over again! Daniel self-rights and rams Paul again, this time into the corner! The spike flips Paul, but D.V.D is invertible and continues its run, spinning up and coming on the attack again!
    CRASH!
    This impact does less damage than the previous hit, but still dents the side armour! But now Daniel decides enough is enough... And slams his axe into Pauls bodywork, making D.V.D shudder violently with the slam!
    Theres no retaliation from D.V.D, so Supreme Glory rams it across the arena to finish off!
    5,4,3,2,1, IMMOBILE!
    Supreme Glory turns Blu-ray to meet All Scoop, while D.V.D is turned into a VHS!
    Coming Next- A middleweight fight!
    T-Minus v Claw and Axe
  6. #196
    PREDICTIONSSSSSSS:
    Claw and Axe to...claw...and axe...T-Minus to oblivion.
  7. #197
    Pah, oh well.
  8. #198
    Guest
    Special Event- Middleweight Heat 2/4:
    T-Minus is another previous winner of the battlebots middleweight chmapionship!Unlike Hazard, however it is a high-pressure flipper that has a srimech!
    Remember Weapon Synergy back in Heat A? Well for his middleweight Daniel Stickler has chosen to take two of its clusters and enter them here!
    Booth 1: Martijn M Benschop
    5,4,3,2,1, DESTROY!
    Claw and Axe split up while T-Minus gets ready for some serious flipping action! Claw comes on a frontal attack, but it is flipped sky-high before Daniel even gets a chance! Axe comes in from behind, but Martijn uses the weight advantage to push it into the corner where its flipped by the spike! Axe self-rights, but T-Minus has turned around and now flips Axe OOTA!
    Claw comes in, but Martijn is ready and flips it, albeit away from the walls rather than over them. But he gives chase and gets underneath again, this time ramming Claw into the side wall before letting it fly again!
    ANOTHER MIDDLEWEIGHT HEAT HAS A PREMATURE END!
    Once again the weight advantage proved too much for Weapon Synergy and Daniel bites the dust! T-Minus goes through to the middleweight semi-finals!
    To Kody- At least your a gallant loser, unlike someone I know (COUGH-MARK-COUGH)!
    Coming Next: The Heat B Final!
    All Scoop v Supreme Glory Omega
  9. #199
    Not much I can do here except charge the corners, try to flip Supreme Glory over, pin it and chuck it out the ring pronto.
  10. #200
    Guest
    Heat B Final:
    All Scoop... v Supreme Glory Omega
    Lets see how these two mechanical monsters got to this stage of the competition!
    1) Supreme Glory Omega started badly in its eliminator, but came back to shatter Dead Horse Beaters base armour and take the match via knockout.
    2) All Scoop proved that a stupidly long name wouldnt count against it and pitted Back to Rock III.
    3) All Scoop had a tough fight with Shadow Zone Returns, but eventually scored an OOTA to claim its place here in the heat final.
    4) Supreme Glory Omega started badly again in its semi-final match, but eventually dealt D.V.D a fatal blow to reach this highly respectable round!
    Booth 1: Steven McGregor
    5,4,3,2,1, DECIMATE!
    Both bots get off to a quick start, heading towards each other! Supreme Glory brings its axe down, but misses as All Scoop veers out of its line of fire and gets underneath the corner! Steven quickly turns SGO onto its back and brings the axe down to stop Daniel self-righting!
    Steven now carries his opponent to the arena wall, and tries to dump him out of the arena! But SGO fires the axe at the right time to self-right off the wall! And beacuse of the direction it falls away from All Scoop before ramming Steven from the side and bringing its own axe crashing down on All Scoops top armour! Daniel gets him into the corner, and All Scoop is flipped by an arena spike! He quickly self-rights, but Daniel was waiting to get under him and now uses the axe as a front hinged flipper to throw Steven onto the wall! The axe dangles over the side helplessly, but Steven uses the scoop and gets his wheels back on the ground! He immediately comes back on the attack, but SGO delivers a whopper of a hit right onto the top of All Scoop! The axe head comes crashing down, and something has fallen off All Scoop!
    The cameras zoom in and we see the removable link lying uselessly on the ground!
    ANOTHER HEAT COMES TO AN END!
    Supreme Glory Omega springs a surprise and claims a place in the series finals! All Scoop is out of the heat and the contest as Daniel goes through!
    Coming Next: The First eliminator of Heat C!
    Worck v Typhoon 2
    Note to Mark- Remember Im not taking that AFR rubbish.
