Aint got any clusterbots... :sad:
But I will enter World Championships!![]()
Weight: 100kg
Armour: 4mm Hardox.
Speed: 18mph - powered by 2 Sinclair C5 motors running at 24v.
Shape: Box wedge with sloped sides, a rounded back and scooped front.
Weapon 1: A cam-driven axe mechanism, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
Weapon 2: A flipping arm, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
Strengths: Fastest axe mechanism currently around (hypothetically of course, this is only a vapour after all€¦)
Weaknesses: The weapon itself is not very destructive, but mainly shows dominance in terms of number of this it can do.
Ground Clearance: 0mm at the front due to a sharpened Titanium front and side skirts, 4mm at rear.
Srimech: Invertible, but the axe mechanism has enough power in it to right it back onto its wheels.
Notes: The axe-head is based on Dominator 2€™s, and has small Titanium spikes on each end to aid in self righting. The axe-head is made of Titanium, with a 5mm Hardox tip. The flipper arm is made entirely out of 10mm Aluminium. The robot has 4 wheels get up in a skid steer system and runs off 2 Sinclair C5 motors @ 24v. Each side is connected to each other by a heavy duty rubber belt, and the wheels are made entirely out of Vulcalore. The weapon systems run off a 60v Briggs and Stratton 11kW motor geared down 15:1. The motor is connected to a cam wheel which in turn moves the weapon up and down on its pivot. When running at 60v, the weapon can move just under 5 times a second. The emphasis is not on power, but in dominance and aggression.
Name: Spawn of Squish
Weight: 100kg
Armour: 7mm Hardox
Speed: 20mph
Shape: Horizontal Crusher shaped (i.e. like TAN)
Weapon 1: A very powerful hydraulic crusher, with 14 tonnes of pressure at the tip.
Strengths: Very powerful crusher and strong armour. Ability to dominate matches.
Weaknesses: Flippers!
Ground Clearance: 1cm all around.
Srimech: Invertible.
Notes: The robot is powered by 2 x LEM130 Lynch motors running at 36v, giving 20mph top speed and has 2 wheels made out of Titanium and Vanadium alloy with a thick coating of Vulcalon for extra grip. There are hundreds of small screws around the wheels, again for grip on the arena floor. The crushing arms are powered by an M-Mac M40 Hydraulic Actuator running at 12v, which can give 14 tonnes of pressure. The actuator has already been used in Robotic Combat, so this robot is realistic. For the weapon to function properly, the robot contains 4 x 12v NiCad batteries. The hydraulic ram is protected at the back by a 5mm Polycarbonate shield, which stops axes and crushers from directly damaging it (although a decent crusher will get through the Polycarb). The whole robot has hundreds of small weight reducing holes around it to get within the weight limit.
Woodpecker will represent Poland.
Spawn of Squish will represent Holland.
