Page 33 of 47 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 461
Thread: My first REAL tournament... ROBOBASH!!!!
  1. #321
    Guest
    I dont care how crap Pauls machine is, Humdrum is going out. XD
    How come your being so nice to Paul Kody?
    I agree with Kodys predictions.
    Heat Winner: Any other time Id say BTR, but in this tourney probably Darkestar or Sakura :P
  2. #322
  3. #323
    So where are you typing from then?
  4. #324
  5. #325
    ...okay...
  6. #326
    From Team Bored. Sakura!
    Taking a leaf out of Typhoon 2, this bot€™s spinner is powered by 2 LEM-130€™s, and this spins at 1500 RPM and deals out 90 to 100 kJ. There are holes drilled in the shell and pink confetti comes out of there. However, the base armour doesn€™t look too strong.
    From Team Doomforall, Darkestar!
    Darkestar is a tracked machine with a 1500RPM spinning flywheel for a weapon. It can also run both ways up€¦ but it€™s got exposed tracks and a vertical spinning weapon can damage the drive belt easily€¦
    From Team Braveheart, Split Decision!
    Split Decision is the 4th clusterbot in this series. It€™s got a forward hinged flipper, powered by gas (but it€™s mostly used as a srimech). Nevertheless, the weight disadvantage is severe, and it can be easily destroyed or flipped.
    Roboteers, Stand By!
    Booth 1: Sakura, Darkestar
    Booth 2: Split Decision
    3€¦ 2€¦ 1€¦ ACTIVATE!!!
    And they€™re off! Now, both of the spinning weapons are up to full speed ahead, and For is immediately going for Sakura, but€¦
    CRASH!!!!!!!!
    WOAHHH!!!!!!! That sent For flying across the arena, there! Now Against and Darkestar charge at each other!!!!!
    CRASH!!!!
    POUNDED. That€™s all I can say. Darkestar€™s blade has sliced right into the titanium armour of Against. Now then, For is driving in circles, and now, Sakura has got another hit in the 7mm titanium armour!
    CRASH!!!!!!!!!!!!!!!!
    OH!!!!!!!!!! The titanium takes another punishment, and now For stops moving! Against is still moving, however€¦ only just. However, Sakura spins up again, and smashes into against!
    CRASH!!!!!!!
    OH!!!! Against is getting smashed again! Sakura just smashes into the armour of Against and the internals show themselves at last! There€™s a battery hanging out of Against€¦ and it€™s safe to say this match is done. The countdown is on!
    10, 9, 8, 7, 6, 5, 4, 3, 2, 1€¦
    CEASE!
    Split Decision gets split up into pieces.
    Sakura and Darkestar go through!
  7. #327
  8. #328
    Sam Park: Welcome back to RoboBash, and we€™ll start off with our 2nd fight of the evening. 3 robots go in, but only 2 comes out alive.
    From Team Humdrum, Humdrum!
    A good machine, with a full body spinner, and 2 maces attached to it. However, there doesn€™t seem to be a srimech attached to it and that vulnerable removable failsafe can be easily destroyed€¦
    From Team Insanity, Autoism!
    Autoism is an insane lifting crusher ala Big Nipper, and it€™s got pliars (what€™s a pliar?) instead of claws. It€™s also quick and has tough armour all around. However, those wheels could easily be targeted by crushers and axes.
    From Team Varying Every Day, Back to Rock!
    Back to Rock has a lifter powered by an LEM-130, and a saw powered by an S28-150. It€™s currently a series semi-finallist in Robot SMASH!. However, the titanium doesn€™t look too strong, and it€™s not as agile as 4WD or 2WD robots. Will he truly rock you?
    Booth 1: Humdrum, Autoism
    Booth 2: Back to Rock
    Humdrum immediately starts spinning up, and now€¦ Back to Rock and Autoism comes out, and smacks into the already spun up shell! Autoism is thrown a bit, but no damage is caused, thankfully. Anyway, Back to Rock comes in now, and lifts Humdrum up€¦ and sparks are flying as Back to Rock€™s saw blade rips the armour of Humdrum. Now, Back to Rock lets go, and Autoism presses the pit button immediately, and Humdrum just spins up again, and goes straight to Back to Rock!
    SMACK!
    That didn€™t cause any damage at all, except flinging Back to Rock a little. Now Autoism goes in and clamps Humdrum, and drags it into the hammers!
    WHAM! BAM!
    OH!!!! Humdrum is getting smashed here! Now, that failsafe is very vulnerable, and€¦ if the hammer knocks out the link,
    WHAM!!
    €¦well, which it just did€¦ it€™s done for! Humdrum is no more, and Back to Rock and Autoism comes in for the kill! Autoism pushes Humdrum into the saws! BZZT! Ah, we love the sparks, yes we do. Now, Back to Rock lifts up Humdrum, and the close-up camera shows that Humdrum€™s tyres have been cut up by the arena saws! Martijn thinks he has had enough of this, and so he slowly begins to push Humdrum into the darkness. BOOM!
    CEASE!
    Humdrum can say hello to Satan for all we care!
    Autoism and Back to Rock go through!
    Round 2 Lineups
    Sakura VS Autoism
    Darkestar VS Back to Rock
    Tactics, Comments, Predictions, and a nice signature for me, done on titanium by Troubloon 6, please.
  9. #329
    quote:
    and a nice signature for me, done on titanium by Troubloon 6, please.Erm...why :S
    Sakura vs. Autoism
    Thats deffo as far as Pauls going to get.
    Darkestar vs. Back to Rock III
    Can go either way but Ill go for Darkestar to chew up those sides.
  10. #330
    Laura (Pit Reporter ): (Comes up to Paul & Autoism) Right, the draw has been drawn. Do you know who you€™re up against?
    Paul: No. (Chuckles)
    Laura: (Laughs) It€™s Sakura.
    Paul: Oooh, it€™ll be pretty tough to bear with, but I€™ll try to wrap my pliars around Sakura and pit it.
    Laura: You think you can do it?
    Paul: Probably, but you never know what will happen out there.
    Laura: Well, Good luck out there.
    Paul: Thanks.
    Laura: And here€™s Frank Goacher with the beautiful and magnificent Sakura! So, your opponent for this battle... Autoism.
    Frank: Well, he€™s got pretty thick armour, and a strong chassis, so my spinning shell doesn€™t look like it will go through it.
    Laura: And?
    Frank: €¦ and I guess the only way to beat him is to shock kill him, or maybe tear his weapon off.
    Laura: Well then, I wish you good luck.
    Frank: Thank you.
    Laura: So, it looks like these teams are both confident. Back to you, Sam.
    Sam Park: So, we€™ve passed the easy stuff, but now, it€™s the calm before the storm. Bring on Round 2!
    Ladies and Gentlemen, please welcome€¦
    SAKURA!!
    A cone shaped machine, capable of dishing out a whopping 90 to 100 kJ. Frank Goacher is looking to shock kill his opponent, as he said.
    AUTOISM!!
    A very nicely made bot, with a crushing lifter, and a nasty attitude. Can it stand up to the deadly and dangerous Sakura?
    Roboteers, Stand By€¦!
    Booth 1: Sakura
    Booth 2: Autoism
    Here we go, now. Sakura is immediately spinning up, and Autoism immediately presses the pit button. Now Sakura is crashing into Autoism!
    CRASH!!!
    Not a bad hit there! It bends the side skirt a bit, but not too much damage is going on here. Now, Sakura spins up to full speed and€¦ what the€¦ pink confetti? Paul doesn€™t like that ONE BIT! So, he drives Autoism front-first into Sakura. What€™s going to happen? Guess.
    CRASH!!!!!
    That attack bends the weapon a little, but it€™s still able to grab a tight hold of Sakura, and now€¦ Paul thinks it€™s time for some saw-time! Autoism carries Sakura into the saws! BZZT!! Ah, how I love a good ol€™ shower of sparks. Now, Autoism lets go, and now€¦
    CRASH!!!!
    Sakura scratches the side armour of Autoism, nothing else. Autoism is okay, and it just smashes into Sakura again!
    SMASH!!!!
    That didn€™t cause much damage, just a itty-bitty scratch again. Now, this is a very good battle so far€¦
    CRASH!!!
    Sakura, what are you doing?! Sakura just smashes into the polycarbonate wall, and takes a chunk of polycarbonate out of it! Now then, Sakura spins up again, and Frank looks a bit nervous. Autoism dances around the arena€¦ and runs into Sakura, front-first AGAIN!
    CRASH!!!
    Autoism takes very little damage, even after that full-speed hit by Sakura! Now, Sakura is spinning its body up to its maximum potential.
    CRASH!!!!
    Autoism collides again with Sakura, and will this go to a judge€™s decision, I wonder? With less than 13 seconds remaining, I€™ve got a feeling it would.
    10€¦ 9€¦ 8€¦ 7€¦
    CRASH!!
    WOAH!! A very teeny-weeny piece of armour flies off from Autoism, courtesy of Sakura€™s spinning shell€¦
    6€¦ 5€¦ 4€¦
    Autoism drives into Sakura but time runs out€¦
    3€¦ 2€¦ 1€¦
    CEASE!
    JUDGES, I WANT YOU TO DECIDE€¦ WHO GOES OUT!
    JD: Sakura / Autoism
    Style: 3/5 / 2/5
    Control: 2.5/5 / 2.5/5
    Damage: 4/5 / 1/5
    Aggression: 2.4/5 / 2.6/5
    Total Score: 11.9/20 / 8.1/20
    Autoism really needs to calm down.
    Sakura goes through to the Heat L Final!
