Yes. If one part of the clusterbots is counted, all the parts of the robots is eliminated.
I still waiting for the 3 robots.
Be patient, Andre. They will come eventually.
Youre right about that, Kody.
Patient.....anytime is just great.
Id just get one more entry and make it a series 4 style heat, with two three way melees at the start.
Ill enter a clusterbot consisting of 2x Flick of the Wrist please
stats in Kody and my boards, you need a link?
If I were you, Andre, Id do the draw all over again.![]()
And Id also like to change my entry, if you do.![]()
Yes. I certainly may need a link for it.
Heres my clusterbot, two identical parts
2x
quote:
Name - Flick of the Wrist
Shape - 6-wheeled Tornado, including the angled rear to keep in contact with the ground while driving up a wedge
Weight - 100 Kilogram
Speed - 35 km/h (22mph)
Dimensions - 120x80x20 cm
Ground Clearance - 10 mm under the main body, variable clearance under the lifting spikes, with 0 mm as a minimum
Power - 2 B42-500 Magmotors at 48 volt
Movement - 6 wheels for awesome traction
Turning Circle - Zero
Weaponry - A pair of hardox, diamond tipped electric lifting spikes, a lot like the lifting spatula of American SHW Vladiator. These are 25 cm in length and can be lifted downwards which turns them into an active invertible lifting wedge. They can also be raised parallel to the floor, so they can act as a pair of classic ramming spikes. A 100 kg robot driving around at 22 mph is good for 5 kJ of kinetic energy. When this is brought onto a pair of diamond tipped spikes, this might seriously harm some armours.
Armour - 7 mm titanium all around
Srimech - It€™s invertible
Strenghts - High speed rambot, awesome traction
Weakness - Lack of devestating weapons
