The semi finals are here...well, one of them is anyway. Ill get the other one done later.
The 6isc (6isk?) vs. Envy
ROBOTEERS, STAND BY
Booth 1, left hand side: Shane Swan, and a man in a penguin outfit
Booth 2, right hand side: Frank Goacher
3
2
1
ACTIVATE
Envy is immediately off, going for the box rush to stop The 6isc from spinning up, but The 6isc saw it coming and dodges the attack rather nicely, moving up towards the top of the arena. Envy gives chase, but The 6iscs weapon is spun up now, and although Envy is able to get underneath one of its opponents wheel pods, the disc makes contact with the side as it does so!
CRASH! And as Envy goes flying, it knocks its aggressor upwards as well! Both machines land, Envy is upside down though...no real problem, as it somersaults back on to its wheels in a cloud of CO2 and speeds away from the incoming 6isc. The robots now square off, Envy trying to manuver around the side of The 6isc, while Frank tries to keep his machines weapon facing the opponent. Theyre moving in some sort of waltz, it would seem...but then The 6isc breaks the deadlock and goes all out at Envy!
CRASH! The 6isc is flung off the wedge of Envy by the force of that hit, which appears to have caused a long dent in Envys flipper arm. Envy is now on the attack though, and drives in under The 6isc!
CRASH! And just like before, the robots are torn away from each other, Envys front now looking rather scarred. Shane continues on the offensive though, coming around and ramming into The 6isc before it can spin up again...slamming it against the top arena wall! The 6isc attempts to drive off the top of Envy, but it only has one set of wheels in contact with the ground, and can do little more than reposition itself on the wedge, before...
FLIP! And the nose of Envy bounces up! It comes down though, and the flipper appears to have done its work, as The 6isc is propped on the angle grinder! One wheel pod is hanging over the arena entrance area, and it would only take a little nudge to send it into oblivion. Envy backs off...Shane fires the flipper again...and comes in to oblige with a tap to The 6isc with the extended weapon, and Frank sets his transmitter down as his robot slides off across the scenery.
CEASE
After a short but sweet battle, Shane Swan and Envy are through to the tournament final!
Comments, aggreived pointings out of what I did wrong, thoughts?
