Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: Futaba 6ex FASST
  1. #11
    Paul, I may consider getting a 2.4gig futaba then
  2. #12
  3. #13
    paul
    whens M2 coming back to fight
  4. #14
    kane's Avatar
    Roboteer
    Paul, its not just robots... Ants trucks have a multifunction unit that doesnt work properly when running from an AR6000. Works fine with standard radio. Apparently the 6EX works fine too.
    Kane Aston
    http://www.makerobotics.com
    Co-owner and builder of BEHEMOTH
  5. #15
  6. #16
  7. #17
    im sure you can prove that when its back on TV
    i have faith that its going to come back !
  8. #18
    The 3 main problems we have with the spectrums are the default neutral is not 1.5mS. Can easily be adjusted using the trims.
    They dont seem to work when really cold, Solved by moving them away from the CO2 stuff.
    The pulses are only upto 3.3 volts, less if external circuit pulls more current. Solved by Resistor changes in mixer board to drive the Opto-Isolators correctly. Bear in mind that most new receivers (including 40MHz) are 3.3V and it really depends on whats attached to weather they will work and even after saying that they are only minor problems and the advantages of 2.4GHz outway them for use.
    Must admit I did like Pauls idea when I first saw M2 of the remote Isolation, does improve safety alot.
  9. #19
    kane's Avatar
    Roboteer
    I have no idea unfortunatley... I dont have the equipment to play with it :sad:
    Kane Aston
  10. #20
