Page 4 of 23 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 222
Thread: Eye Of The Robot-Series 4
  1. #31
    The Combat Kings tournament took AJ and I 2 weeks to fill with 8 people, and we had to bug them constantly on MSN to get their entries in :P
    Scale down and give the more time
  2. #32
  3. #33
    please consider cutting this down to 8 entrants, the fact that you got 12 last time doesnt mean youll get 12 this time
  4. #34
  5. #35
  6. #36
    Hmmm...this seems like as good a place as any to have my vapours trashed for the first time :P
    Team Chevron
    Gabriel (v1.2)
    Fire And Ice (stats to follow, Im modifying it to get it in 100kg)
    Nidhogg
    147
    As for realies, Ill have 13 Black (S7), Dreadnaut (XP1 version, S4), Panic Attack (Extreme 2) and Darke Destroyer (S3)
    EDIT: Stats for all in How Could I Improve, except for:
    Fire And Ice
    WEIGHT: 100kgs
    DIMENSIONS: 75 x 55 x 22 cm
    SHAPE: Invertible box, with a wedge at the front and an inverted wedge at the back.
    COLOUR: Flame red and yellow at front, icy blue and green at back.
    DRIVE: 4 LEM130 motors running off NiCd packs at 36hp driving steel-reinforced rubber tracks.
    SPEED: 16mph average, 25mph max (rarely used as it is difficult/impossible to turn at this speed)
    GROUND CLEARANCE: 10mm at sides, hinged plating extending below both wedges giving zero clearance on whichever side is down (if that makes sense...), 23cm at rear.
    ARMOUR: Front and rear are 6mm hardox, with the sides, top and underside being 4mm titanium.
    WEAPONS: Mainly relies on speed and ramming power, but also has two 20cm diameter diamond edged sawblades, one in the centre of each wedge (a la Angel Of Death from S2) each powered by an Ampflow E-150 motor to around 3500rpm. The saws spin upwards to have some lifting effect as well.
    SRIMECH: None, but runs inverted. Has spike strips on the sides to prevent stranding.
    NOTES: Armour and components shock mounted to reduce impact from all things large and spinny.
    STRENGTHS: Good speed and power, good against spinners
    WEAKNESSES: Tracks vulnerable to axes
    (Message edited by joeychevron on February 21, 200
  7. #37
  8. #38
    Heres Killobite 5.0!
    http://strickenone.proboards99.com/index.cgi?board=heavies&action=display&thread=16http://strickenone.proboards99.com/i...display&thread =16
  9. #39
    Right - Ive decided to clear Samuel of his spot, so now I have 7 people signed-up and I just need 5 more people. Alex McW? Richard? Steven? Danny? Matty (If hes still about :wink?
    Heres the current list:
    1-Martijn Benschop (Team Varying Every Day)
    a. Storm 2
    b. Big Nipper
    c. Axe To Fall 2
    d. Flick Of The Wrist 2
    e. Sheer Heart Attack 2
    f. Another Night At The Bar
    g. Back To Rock 3
    h. With Or Without You
    2- Kody Kunz (Team Zlayerz)
    a. Wedginator 6.0
    b. Super Gore Evo
    c. Seung Mina III
    d. Aftershock
    e. Intrigue
    f. Killobite 5.0
    g. Turbulence
    h. Shrederator
    3- Alex Holt (Team DoomForAll)
    a. Kali
    b. Black Panther Queen
    c. Ramthrax 2
    d. Achilles
    e. Tengu VII
    f. Cable
    g. Robot The Bruce
    h. Bodyhammer
    4- Dave Sheppard (Team Jimmy McGee)
    a. BioHazard
    b. M2
    c. Atomic
    d. Suicidal Tendincies
    e. Quocunque Jeceris Stabit
    f. Chalkie 3G
    g. Son Of Wedgie
    h. Flipping Mad B2B
    5- Christopher Mason (Team Dinowarrior)
    a. Orka MK.4
    b. Die-Ceratops ReInvertus
    c. Leprosy Infection
    d. Crash Bandi-Bot 3
    e. Spring-BOK!
    f. Squirmin Vermin
    g. Humdrum
    h. Axe-O-Lotl
    6- AJ (Team ???)
    a. Tornado
    b. FireStorm 5
    c. SOR X
    d. Wedga€™s Revenge
    e. Exertion
    f. Psycloniser
    g. The Final Cut
    h. GeForce 4.0
    7- Joey McConnell (Team Chevron)
    a. Gabriel V1.2
    b. Fire And Ice
    c. Nidhogg
    d. 147
    e. 13 Black
    f. Dreadnaut XP1
    g. Panic Attack
    h. Darke Destroyer
    8- ???
    a. ???
    b. ???
    c. ???
    d. ???
    e. ???
    f. ???
    g. ???
    h. ???
    9- ???
    a. ???
    b. ???
    c. ???
    d. ???
    e. ???
    f. ???
    g. ???
    h. ???
    10- ???
    a. ???
    b. ???
    c. ???
    d. ???
    e. ???
    f. ???
    g. ???
    h. ???
    11- ???
    a. ???
    b. ???
    c. ???
    d. ???
    e. ???
    f. ???
    g. ???
    h. ???
    12- ???
    a. ???
    b. ???
    c. ???
    d. ???
    e. ???
    f. ???
    g. ???
    h. ???
  10. #40
    This I do not understand. You are already struggling to get your tournament started because there arent enough players, yet you wipe a player because you didnt get his stats in time? Why would it matter anyway? The board is not full so the tournament cant start so what if he is a little late with his stats?
