Results 1 to 5 of 5
Thread: Replacing zeobot base
    hi all
    with having new armour made i think it would be sensible to change the base of psycho fling. at the moment it is a zeobot one with holes all over and i believe it to be 6mm. my plan is to change that to 4mm making it 800g lighter
    i am doing this because the zeobot wheel holes are casing alot of compromise and parts of the base un useable
    so im just checking if it will be strong enough?
    thanks alex
    I plan to use 4mm in DB5 base at some point so yes it will be strong enough.
    i was just thinking would instead of 4mm aluminium if i went for 2mm steel would this be strong enough? it comes out at the same weight as the original 6mm sheet
    just thought i might be able to get it easier
    where are you getting your aluminium from ed?
    thanks alex
    Depends what type I get, I usually buy thinner stuff from Technobots.
    i use the 4mm ali from technobots in hornet 2. Great stuff to work with and very strong.
