Results 1 to 4 of 4
Thread: Battery trouble
    hi all
    just making a prototype of the base of my crusher, but my charger doesnt seem to think that one of the batteries is attached to it. i tried to charge it and it beeps and says no battery. but my other two charge fine.
    i seem to get a voltage reading so im confused. i havent tested the drivbe yet so dont know if there is a big problem, but there is with charging. any ideas?
    thanks alex
    kane's Avatar
    Roboteer
    Possibly a dead cell/ duff pack.
    Kane Aston
    http://www.makerobotics.com
    is there anything i can do about it? i dont have much knowledge about batteries
    alex
    Probably best not to do anything unless you have much experience. You will need to take the pack apart and test the voltage of each cell. They should all be the same, if one or more is down on voltage then probably duff. The problem then comes when you have to replace it with a cell that is matched to the existing ones.
    Probably less time consuming to get a new pack. I have lots of cells at home which all need testing and sorting, just dont have the time.
