kody i believe this thread was about sam introducing himself and his robots![]()
Wiseass![]()
Id like to see what else Samuel has back in his virtual garage though. :wink:
and introducing Hex,
Weight: approx 127kg
Size (L/W/H): 140cm/80cm/80cm
Speed: 10mph
Ground Clearance: 80mm
Drive:12x Custom servo gearmotors
Weapon: hydralic claws which lift via a linear actuator and the pneumatic tail which can selfright
Armour/Chassis: 8-6mm hardox plate welded
Batteries: 2x12v 16A hawkers
Notes: its a walker
http://www.flickr.com/photos/tanto818www.flickr.com/photos/tanto818
Let me see if i get this straight:
You would have 2 servo motors on 1 leg, 1 to lift the leg and 1 turning it?
I doubt you will get it in 130 kg though, with hydraulics and pnuematics and the Hardox, but i cant say for sure since I dont know the weight of each servo (which will not be light either to have that much torque).
oh and btw, the design itself looks great!
your quiet right 130kg is way off, dont know where that went wrong, ill recheck that
yea one to go up one to turn
As far as I know, true walkers have a 200 KG limit, so youve got some sparee to play with there.
True walkers can indeed be 200kg in the heavyweight class, which this robot would definatly qualify as.
OK, I made a robot and this time its going to be sweetly brutal. So, here we go.
Turbo Shredder
Shape: La Machine
Weight: 96 kgs
Top Speed: 15 mph
Armour: 4mm Stainless Steel All Around
Skirts: One Skirt on the front
Ground Clearence: 0mm around the front, and 2.1mm on the back and the sides
Wheels: 2 X Wheels Inside (Aluminum Hub)
Power: 2 X Lem-130s running on 36 volts
Battery: 8 X BPK-3600-36 BattlePacks
Weapons: A very nasty 19kg, 3700RPM vertical spinning disc powered by a single magmotor on 24V, capable of dishing out 83kJ
Srimech: An Electric Bar at the rear powered by a linear acutator.
Strengths: Powerful Weapon, Great Pushing Power
Weaknesses: None Hopefully![]()
(Message edited by samuel3764 on December 14, 2007)
8 battlepacks 36V is 20kg of battery. you might want to cut down on that.
