Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Thread: HELLO!
  1. #21
  2. #22
  3. #23
    I would recommend a different name, actually.
    EDIT: Theres already another bot with Shredder in its name...
    (Message edited by kodster on December 14, 2007)
  4. #24
  5. #25
  6. #26
    So the only modification you made is increasing your discs RPM output by 100?
    EDIT: Nice edit there.
    (Message edited by kodster on December 15, 2007)
  7. #27
  8. #28
    Still, there are better armour choices out there. Look at some values for titanium or Lexan.
    Also, running out that amount of kJ on the disc you will incapacitate yourself when your disc comes into contact with another bot. Id estimate that your disc would put out about 30-40kJ. Dont take those values, though, theyre just examples. Try and calculate it, or dont put a kJ value up at all if you cant figure it out.
  9. #29
    http://www.teamcosmos.com/ke/ke.shtmlhttp://www.teamcosmos.com/ke/ke.shtml
    With many thanks to Martijn (If I remember correctly) who gave me the link.
  10. #30
    RedBack
    Weight: 98kg
    Size (L/W/H): 60cm x 60x 20
    Speed: 114mph
    Ground Clearance: 7mm
    Drive:4 Dewalt powerdrives
    Weapon:FBS powered by 2x S28-400 Magmotors 3:1 ratio
    Armour/Chassis: 4mm Hardox with 10mm teeth
    Batteries: 2x12v 16A hawkers
    Notes: cant selfright
    http://www.flickr.com/photos/tanto818www.flickr.com/photos/tanto818
