Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Paint Ball High Pressure Filling Kit
  2. kane's Avatar
    Roboteer
    Most paintball suppliers produce paint ball bottle filling kits like http://www.hamburgerhill.co.uk/splat...ation.aspthis.
    Kane Aston
    http://www.makerobotics.com
    kane's Avatar
    Roboteer
    Also, it is not important what your gas bottle weighs while filling. It is only an indicator of what is going in.
    It is most important that you check the weight of your full bottle on the scales to ensure that you do not exceed the gross weight stamped on the bottle. If you exceed this weight (which is very easy to do with a cold bottle) you are liable to blow out the burst disc once the bottle warms up a little.
    Kane Aston
    Andrew, I weigh the bottle empty first, then after filling i weigh it again. a 12oz bottle like yours is good for 340 grams, so if your bottle is 700 grams, your total weigh should be around 1000 to 1050 grams after filling. if it is too much just open the bottle a litte and release some CO2 and weigh again.
  6. no, I think people who helped Andrew the first time to fill it up dont understand the way you safely take off the pressure from the bit in between the 2 bottles.
    A CO2 bottle doesnt blow the second it is overfilled, it can take well up to half an hour to finally build up enough pressure to pop de burstdisk. Thats why you must look at the weight before and after filling. Weighing in between is only a nice guideline to see how far you are but does not add to safety.
  7. #8
