This might seem strange, but when I first heard of this part of the FRA, I just had to join! My name is Paul Cuomo, and my Team is Italien Stallion. Tell me what part of the stats are unrealistic:
KAY 9
€ WEIGHT: 95KG.
€ ARMOUR: 12MM HARDOX
€ SHAPE: REVERSED INVERTED STORM 2
€ MOTORS: 2 x LEM200 AT 46V = 36HP
€ LOCOMOTION: 4 x ALUMINIUM WHEELS WITH HARDOX SPIKES FOR GRIP
€ DIMENSIONS: (W) 60CM (L) 60CM (H) 30CM
€ COLOUR: BLUE WITH SHARP TEETH FRONT SCOOP
€ WEAPONRY: 2 x 20 KG HARDOX FLYWHEELS WITH TWO BLUNTNED HARDOX TEETH AT FRONT. EACH SPINS AT 1200RPM. WHEN FLIPPED, THE WEDGE CAN MAKE IT A PUSHER, AND HAS AN EXTENSION TO GET UNDER THINGS
€ SPEED: 20MPH.
€ GROUND CLEARANCE: 10 MM.
€ STRENGTH: POWER OF DRIVE AND WEAPON.
€ WEAKNESS: HIGH GROUND CLEARANCE AT SIDE AND REAR
SCHMAX
€ WEIGHT: 95KG
€ ARMOUR: 5MM HARDOX ON SIDES/FRONT/BACK. 7MM POLYCARBINATE ON TOP.
€ SHAPE: INVERIBLE BOX WITH FRONT POINTED WITH CUT-OFF END FOR PUNCHER
€ MOTORS: 6 x 750WATT AT 24V = 6HP (GEARED FOR 12HP)
€ WHEELS: 6 x SLICK WET GO-KART TYRES
€ DIMENSIONS: (W) 50CM (L) 60CM (H) 20CM
€ COLOUR: FRONT/SIDES/BACK; BLUE WITH ORANGE TIGER STRIPES. TOP; SLIGHTY GREEN
€ WEAPONRY: 12KG HYDRAULIC PUNCHING RAM. 200 MPH TOP SPEEDS. THREE WAY SCOOP WITH EXTENSION
€ SPEED: 16MPH
€ GROUND CLEARANCE: 2 MM
€ STRENGTH: SPEED AND POWER. STRONG WEAPON
€ WEAKNESS: HARD TO CONTROL
INVERTEX
€ WEIGHT: 96KG
€ ARMOUR: 13MM TITANIUM
€ SHAPE: SHORT BODY WITH SPIKED WHEEL-GUARDS AND CURVED ENDS
€ MOTORS: 2 x 2.5 KW AT 24V. = 4HP
€ LOCOMOTION: 4 x SLICK WET GO-KART TYRES
€ DIMENSIONS: (W) 30CM (L) 40CM - WITHOUT FLIPPER 80CM - WITH FLIPPER (H) 40CM
€ COLOUR: BLUE WITH ORANGE TIGER STRIPES
€ WEAPONRY: 1000PSI FLIPPER. DUAL RAMS. 3 TONS FORCE ON THE SCOOP, 5 TONS IF FULLY UNDERNEATH OPPENENTS
€ SPEED: 13MPH (HIGH ACCELERATION)
€ GROUND CLEARANCE: 0MM
€ STRENGTH: STONG WEAPONRY
€ WEAKNESS: IMPOSSIBLE DESIGN!!!
HITAER 1
€ WEIGHT: 110KG (SHUFFLER)
€ ARMOUR: 10MM HARDOX
€ SHAPE: HEXAGON
€ MOTORS: 4 x 1 KW AT 24V = 2.5HP
€ LOCOMOTION: 2 x RUBBER LEG CASTERS, 3 FEET EACH
€ DIMENSIONS: (W) 50CM (L) 55CM (H) 30CM
€ COLOUR: GREEN WITH WHITE AND ORANGE STRIPES
€ WEAPONRY: 20KG AXE, POWERED BY TWO HYDRAULIC RAMS AT 3000PSI. THE AXE COMES DOWN AT 300MPH - 30KJ OF FORCE. SPIKES ON THE FRONT TWO POINTS HELP KEEP ROBOTS IN HAMMERING LINE. SPIKES AROUND THE EDGES ARE MADE OF STEEL/HARDOX
€ SPEED: 22MPH
€ GROUND CLEARANCE: 1MM
€ STRENGTH: FEROCIOUS SPEED AND WEAPON
€ WEAKNESS: UNUSUAL SHAPE
CRUSHER C.U (CUTTING.UP)
€ WEIGHT: 100KG
€ ARMOUR: 12MM TITANIUM/ 5MM TUNGSTEN STEEL
€ SHAPE: INVERTIBLE BOX WITH FRONT FIXED SCOOP
€ MOTORS: 2 x LEM 200 AT 36V = 47HP
€ LOCOMOTION: 8 x SCOOTER WHEELS
€ DIMENSIONS: (W) 40CM (L) 60CM (H) 20CM
€ COLOUR: BLACK WITH SILVER LINING
€ WEAPONRY: SCOOP WITH VACUUMS TO TRAP OPPENENTS. A DOUBLE-SIDED CRUSHER COMES IN, WITH 6 TONNES ON EACH. REAR SPIKES
€ SPEED: 17MPH
€ STRENGTH: UNIQUE DESIGN
€ WEAKNESS: UNIQUE DESIGN
FLUX
€ WEIGHT: 95KG
€ ARMOUR: BODY - 10MM ALUMINIUM, 12MM BOMB-PROOF POLYCARBINATE, 6MM TITANIUM. SKIRTS - 10MM HARDOX.
€ SHAPE: INVERTIBLE RAMMING BOX
€ MOTORS: 4 x LEM 130 AT 36V = 54HP
€ LOCOMOTION: 4 x VULKOLON WHEELS
€ DIMENSIONS: (W) 50CM (L) 50CM (H) 17CM
€ COLOUR: BODY; BLUE WITH ORANGE STRIPES. SKIRTS; VERTICLE GREEN, WHITE AND RED STRIPES
€ WEAPONRY: NON-FIXED SKIRTS. EACH SKIRT IS 5KG IN WEIGHT
€ SPEED: 26MPH
€ GROUND CLEARANCE: 0MM (SKIRTS)
€ STRENGTH: INVERTIBLE WITH NON-FIXED SKIRTS
€ WEAKNESS: NO DAMAGING WEAPONS
ZEE DRUM
€ WEIGHT: 94KG.
€ ARMOUR: 15MM TITANIUM
€ SHAPE: INVERTIBLE BOX-LIKE WITH OVAL SIDES
€ MOTORS: 4 x LEM 130 24V = 27HP
€ LOCOMOTION: 8 x VULKALON TYRES (2 POWERED PER MOTOR)
€ DIMENSIONS: (W) 55CM (L) 66CM (H) 15CM
€ COLOUR: SILVER AND GOLD
€ WEAPONRY: 30KG HARDOX, STEEL AND TITANIUM DRUM WITH 20 BLUNT TEETH, 3000RPM.
€ SPEED: 25MPH.
€ GROUND CLEARANCE: 0MM.
€ STRENGTH: POWER AND WEIGHT OF WEAPON.
€ WEAKNESS: SPIN-UP TIME.
HYENA
€ WEIGHT: 100KG
€ ARMOUR: 5MM HARDOX/ 20MM BOMB-PROOF POLYCARBINATE/ 12MM TITANIUM
€ SHAPE: INVERTIBLE RECTANGLE WITH FRONT LOW EXTENSION, SPIKED SIDES AND REAR FLYWHEEL
€ MOTORS: 2 x 3KW AT 36V = 10HP
€ LOCOMOTION: 10 x 13CM VULKALON RUBBER WHEELS
€ DIMENSIONS: (W) 50CM (L) 80CM (H) 14CM
€ COLOUR: GOLD WITH BLACK SPOTS
€ WEAPONRY: AT THE FRONT IS A 5CM WIDE AND 8CM LONG EXTENSION, THIS IS THE FIRST PART OF A JAW SYSTEM. THE SECOND PART WORKS LIKE AN AXE AND IS ANOTHER 5CM WIDE 8CM LONG TITANIUM PLATE. THE JAW IS MADE OF HARDOX WITH 5 6CM TEETH MADE OF ENLIGHTENED HARDOX, AND IS POWERED BY 3 HYDRAULIC RAMS AT 3000PSI (EACH) AND USES VERY FAST RAMMING ABILITES TO COME DOWN AT 300MPH, ENOUGH TO GRIP ANOTHER ROBOT AND CRUMBLE IT€™S ARMOUR. AT THE REAR IS THE SKIRT-KILLING FLYWHEEL - WEIGHING 15KG AND USING 1 x LEM 200 AT 48V TO SPIN AT 2500RPM. 5MM THICK AND MOUNTED 1MM OFF THE GROUND. SIDE SPIKES PROVENT IT GETTING BEACHED.
€ SPEED: 20MPH.
€ STRENGTH: BRILLIANT WEAPON COMBINATION
€ WEAKNESS: DIFFICULT CONCEPT TO UNDERSTAND
EYZ
€ ARMOUR: 8MM HARDOX WITH 2 INCHES OF VULALON RUBBER AROUND IT.
€ MOTORS: 4 x LEM 200 AT 48V = 80HP
€ LOCOMOTION: 4 x SHUFFLING PADS, EACH COVERED IN VULKALON RUBBER, 6 FEET ON EACH PAD
€ DIMENSIONS: (W) 60CM (L) 80CM (H) 14CM
€ COLOUR: SHINY WHITE WITH A BLACK PUPIL IN THE MIDDLE OF A BLUE EYE
€ WEAPONRY: A SPINNING RING IN THE MIDDLE OF THE ROBOT, WHICH WORKS LIKE A FULL BODY SPINNER, EXCEPT IT€™S A RING. THE RING IS 50MM G5 TITANIUM WITH 10MM HARDOX RINGS ON THE SPINNING RING. THIS MAKES IT LIKE A CAGE, AND IT€™S GOT SPIKES WELDED ONTO EACH PIECE OF HARDOX. THE SPIKES ARE MADE OF TUNGSTEN STEEL. THE WEAPON WEIGHS 36KG AND SPINS AT 2300RPM. 260KJ OF FORCE WITH EACH IT. WHEN IT HITS AN OPPONENT, THE RING ONLY SLOWS DOWN EACH TIME BY 500RPM. THE WHOLE THING GETS UP TO SPEED IN 0.8 SECONDS.
€ SPEED: 22MPH.
€ GROUND CLEARANCE: 0MM (SKIRTED)
€ STRENGTH: EVERYTHING! WEAPON MOSTLY
€ WEAKNESS: NOTHING!
S.O.A.B
€ WEIGHT: 150KG (WALKER)
€ ARMOUR: 7MM HARDOX/ 30MM TITANIUM
€ SHAPE: INVERTIBLE BOX WITH SLIGHTLY ROUNDED FRONT AND REAR. SIDE SPIKES TO PREVENT STRANDING
€ MOTORS: 2 x 55hp PETROL MOTORS = 110HP!!
€ LOCOMOTION: 10 STAINLESS STEEL LEGS WITH RUBBER FEET
€ DIMENSIONS: (W) 80CM (L) 90CM (H) 30CM
€ COLOUR: RED/BLACK WITH THE NAME IN PURPLE
€ WEAPONRY: DIAGONAL SPINNING DISC. MADE OF 20MM HARDOX, IT WEIGHTS 30KG AND SPINS AT 5000RPM
€ SPEED: 17MPH.
€ STRENGTH: WEIGHT
€ WEAKNESS: 2 SECOND SPIN-UP TIME FOR WEAPON
24K KUTTER
€ WEIGHT: 99.5KG
€ ARMOUR: 7MM HARDOX/12MM TITANIUM/5MM ALUMINIUM
€ SHAPE: INVERTIBLE CYLINDER ON ITS SIDE
€ MOTORS: 2 x LEM 130 AT 46V = 18HP
€ LOCOMOTION: 2 METAILLIC WHEELS WITH VULKALON RUBBER TO PROVIDE EXTRA GRIP
€ DIMENSIONS: (W) 50CM (L) 30CM (H) 30CM
€ COLOUR : GRAVEYARD GREY WITH ORANGE TEETH
€ WEAPONRY: A FULL BODY DRUM. IT€™S A 30KG DRUM, SPINNING AT 6000RPM! THE TEETH ARE HARDOX, AND THERE ARE 3 OF THEM 5CM LONG AND BLUNT
€ SPEED: 25MPH
€ GROUND CLEARANCE: 6CM
€ STRENGTH: DESIGNED TO BE HARD TO GRAP
€ WEAKNESS: 6CM GROUND CLEARANCE
SKY-BLAST
€ WEIGHT: 100KG
€ ARMOUR: FRONT/TOP 10MM HARDOX. REAR/SIDES 20MM ALUMINIUM
€ SHAPE: BOX WEDGE WITH CONVAVE FRONT, ALSO CONCAVE SIDES AND A ROUNDED REAR
€ MOTORS: 4 S28-300 MAGMOTORS AT 24V = 80HP
€ LOCOMOTION: 4 VULKALON WHEELS
€ DIMENSIONS: (L) 50CM (W) 40CM (H) 29CM
€ COLOUR: SKY-BLUE WITH WHITE CLOUDS
€ WEAPONRY: A FIRESTORM STYLE FLIPPER ON TOP. FULL-PRESSURE CO2 FLIPPER, CAPABLE OF FLIPPING 3000KG.
€ SPEED: 32MPH
€ GROUND CLEARANCE: 2MM AT SIDES
€ WEAKNESS: NONE!
MeCANNIBAL
€ SHAPE: INVERTIBLE LOW CYLINDER
€ MOTORS: 2 x ETEKS AT 46V = 30HP
€ LOCOMOTION: 2 SHUFFLING PADS
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 15CM
€ COLOUR: BLACK WITH SCARY HUMAN FACE WITH OVER SIZED TEETH COLOURED RED.
€ WEAPONRY: RING SPINNER, MADE OF 20MM HARDOX, WEIGHTING 42KG, SPINNING AT 3500RPM, PRODUCING 215KJ PER BLOW. IT HAS 6 BLUNTENED TEETH MADE OF HARDOX. THE TEETH ARE SET IN A TRIANGULAR SET UP. HAS 3 INCHES WORTH OF TITANIUM SHOCK-PROOF FOAM TO STOP IT SELF-DESTRUCTING.
€ SPEED: 22MPH
€ GROUND CLEARANCE: 0MM (HAS A FULL-BODIED SKIRT RUNNING ALMOST COMPLETELY ALONG THE GROUND)
€ STRENGTH: SCARY NAME AND WEAPON
