Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Cutting Alu
  2. use a corse metal cutting blade medium fast speed but make sure you hold on tight to the jigsawas sometimes it will grab
  4. no probs but be carfull please
    Using a cutting oil solution/coolant will help as ally tends to get hot and clog blades, I also use it when drilling, softer grades of ally are worse for this.
    It does make a bit of a mess though and keep it away from your electrical bits!
    What thickness and grade of aluminium are you using?
    I find that even the 5mm stuff off technobots can take a while depending on how sharp and new my blade is.
  8. Modern plastic drainage systems can have (particulaly smaller dia. access covers) cast aluminium covers. How thick is the cover in question? cast is not as tough as rolled or extruded ally.
