It will give you a fighting chance certainly.
Will 1.5mm thick ali box section welded hold out?
u dont need any :P spinners r rly easy to beat
more about driving skills and tactics imo
planning on putting 2 x 9.6v drill motors in each half of the clusterbot, what voltage could i put in these? i was planning on using 15amp electronize and 2 x 8.4nimh packs in each half of the robot.
You could put 100V through them but I doubt they would last long![]()
Seriously though, I wouldnt go for much more than around the 14V mark. I go for the rule that if overvolting a motor and unsure about how far to go, go 1.5 times above the rated voltage.
If it is a cluster bot though you may be watching the weight. 9.6V through them will still provide a competitive drive system.
so you think i would be best going with 2 7.2v packs? as i have plenty of these lying around and would save buying new.
(Message edited by ady on September 18, 2007)
14.4V would be a very nice voltage for a set of 9,6V drillmotors.
I agree with Gary, 1.5 times the nominated voltage is usually best for overvolting motors.
14.4V would be better yes, but 16.8V should be ok although it might start getting a bit too fast to control, espcially as Electronizes dont have as fast a response time as other speedos (still perfectly good speedos though) What size wheels are you using by the way? As the bigger the wheels, the faster itll go, particularly at 16.8V.
Kaizer weighed 6kg at the Eurochamps and had two 9.6V motors on 14.4V and 75mm wheels - plenty of speed and enough torque for the raptors. Drumroll weighed 1.5kg more but was still able to push the full 12kg feathers about no problem (that was 9.6V motors at 12V on 100mm wheels)
Any pics of this clusterbot yet?![]()
(Message edited by K_C_R on September 18, 2007)
it will be fitted with the 75mm blue wheels. no pics yet will post some,dont like to post them when its still not finished! i been spending the last couple of weeks finishing my daughters robot KAHN,did put a pic briefly on profile. that thing is really good and i believe it will do very well at events, its alot stonger than prodigy was and that always served me well.
i want to concentrate on the fw cluster now, along with selling the house, starting up the new business shortly, and everything else!
With 75mm wheels 14.4V will work quite nicely, should give you a speed of approx 6.6mph (10.5km/h) based on a 500rpm motor (most standard drill motors).
And posting pictures when its not finished allows your opponents (i.e. us) to see any potential weak spots in the construction - not so easy to do when you post pictures of it with all its armour on! Silly billy
Sounds good though - hope to see it in action soon (will it be at Thinktank??)
