Results 1 to 2 of 2
Thread: Few more questions
    Guest
    I have the 25amp viper marine speed controllers are these any good?
    I also have the drill motors off gimson robotics.Link-
    http://www.gimsonrobotics.com/shop_dc-electric-motors.htmlhttp://www.gimsonrobotics.com/shop_d...ic-motors.html
    For these i want ni-mhs or ni-cads what battery power will i need?
    What link is best for a feather 30amp or 50 amp?
    Thanks.
    Dan.
    Dan, the marine controllers should be ok as long as they can handle both the voltage and current you will put through them.
    I would look at battery packs in the region of 9.6v up to 12v with a capacity of 2Ah to 3Ah.
    Either link will be fine. I would go for the 50amp link if you have the space/weight available for it.
