So thatll be Glen Metals ARM400, looking at the website. Likely very similar to Hardox from the description. I think Id still be happy to take the remainder of that sheet to beef up the armour on Ka-Pow!
Is this the minimum sheet size they sell?
The minimum order is 1 sheet at 3 meters*1.5 meters. The cost to me including VAT and carrage is £226.65p.
I do hope this information helps.
Hi Craig
I would also like some bits of this material..will see ya at Hemel ..to haggle / natter
Cheers Tony
The ARM400 is at the sheet metal workshop for cutting, they are €œHaving Kittens€ about breaking their guillotine cutting the sheet into manageable bits, I don€™t know if this will be a problem they can cut 6mm stainless ok. But they want to ring the supplier to ask if they can use their machine before committing to cutting the metal this delay means I may not have it for Hemel Hempstead but I should have it for the winter tour I hope to go to 2 events in that series.
Rule of thumb when sheering Hardox....as I recall... is to treat it as steel twice the thickness.
Hi Guys,
does anyone have or know the best place to buy
3.2mm hardox im not sure if the grade is 450,
there was an old post that i cant find now and it said
that jl steel sold it for £120, + £120 p+p...ouch
i need about 1 sq meter
cheers
Terry.
240 sounds a bit steep for hardox. I have only bought 1 sq m, 5mm off Gary for around 100 pounds including P&P.
What about 4mm I heard its cheaper? Or must you use 3.2?
Im curious as in a few months time I will be ordering some hardox.
Try http://www.abbacommercials.com/Equipment/index.aspxhttp://www.abbacommercials.com/Equipment/index.aspx
I believe the £120 p+p is for 1 sq meter of floor area on the back of a flat bed lorry.
jl steel want £65+vat p+p per pallet size order.
You can get up to 1250 X 1250 on a pallet.
the 4mm hardox is £91 + vat for 1250 x 1250
or £61 + vat for 1000 x 1000.
they said i can have more than 1 sheet on a pallet per order if anyone else requires some.
the reason i did want 3.2 was last year i got 1mt sq from gilbert grimm, 4mm is 31.4kgs per mt sq and puts my weight over !
i bought 4 sheets of 1000mm by 500mm from Abba commercials and it cost me £210. they were good enough to wrap it and post it which cost around £20 if i remember. Which is nice
