if i was to buy from tecnobots would these leads be the right ones
http://www.technobots.co.uk/acatalog/Online_Catalogue_Charging_Leads_2.htmlhttp://www.technobots.co.uk/acatalog...g_Leads_2.html
top 2?
alex
top 2?
alex
as long as you dont mix up positive and negative you can do whatever you want with the leads. However for a good detection of delta peak on the nimh/nicads i recommend as little in between connections as possible.
2 leads with the proper connectors on either end (thats what i meant with other side) gives the best charge results. So 2 banana plugs, 2 leads, 1 tamiya connector for your nicads or nimhs. You could als get a female tamiya connector and put it on your SLA.
top 2?
That would do it.
Those would be fine. Quite cheap too for made leads.
Reveving old threads![]()
Im currently looking for a charger capable of handling Lithium, NICD, NIMH and PB, and came across the http://www.amainhobbies.com/product_.../20720Hyperion
this is the one i have think it does all those battery types, charges and discharges (you would need to buy some leads with it though)
http://www.technobots.co.uk/acatalog/Online_Catalogue_Universal_Chargers_28.htmlhttp://www.technobots.co.uk/acatalog...argers_28.html
its this the - Pro-Peak Sigma AC/DC Charger to 5A (third one down)
alex
