does anyone know of english companies shops which sell this charger or similar?
i seem to be able to find it in france or other countries but not england
thanks alex
thanks alex
just looked through the posts again and realised the second one woody has put up is from england
but will it do all the same things as the other one?
and will it do everthing i need it to
i.e charge-
7.2v nicad
8.4v nimh
12v SLA battery
also will it charge these in the same/ similar time to the swallow charger?
apoligises for all the questions, just want to get the best charger for my money
thanks alex
It will do all the things that you have listed.
i think i have found it slightly cheaper
http://www.btowstore.com/epages/Store3.sf/?ChangeObjectID=86292&ChangeAction=AddToBasket&Las tViewObjectID=86292&ViewAction=Viewhttp://www.btowstore.com/epages/Stor...angeAction=Add ToBasket&LastViewObjectID=86292&ViewAction=View
also found a used one on ebay, the seller stated that the charger charged a nimh 4200 pack in around an hour. i asked the voltage 7.2v, but from particularly dead 0.9v
seems good times to me, are they?
thanks alex
Look fine to me.
i have got one of the propeak sigmas for my birthday, but it doesnt include the leads for charging-it has a set for chrging USING and external battery and a plug for the plug socket
what should i be buying? i need to charge both lead acid battery and nicad/nimhs
any recommen=dations would be appreciataed
alex
Well, your charger uses banana plugs (I did not make that name up, I swear), so you need those one one side. The other side can be crocodile clamps for the lead acid, and bullet or deans ultra or powepole or Tamiya connectors for the nicad/nimhs. Are they ready made packs? They usually already have a style connector on them.
you can get banana plugs from alot of places, maplin being one,
As does Technobots.
yeh they are ready made packs tamiya connectors-, what do you mean by the other side? i was thinking if i have a tamiya connector on the end i can charge the nicad/nimhs and then make an atachment to go onto that that will then connector to a sla, would that work?
alex
