Results 1 to 9 of 9
Thread: Firing mech and reverse
  2. so are you using a servo with a wire on that moves and conects by touching the other wire?? would this pass tech check??? use a relay and have a rc switch from technobots to work it
    1. Whats your weapon motor
    2. You can get RC relay switches that would be up to the job as Kenny has hinted - what relays youd use would depend on the motor (current draw) though
  5. Whoopsie lmao, memory gone to fuzz
    For that motor a relay switcher will be all you need
    The Bigger Dual Ended Switch here: http://www.teamdelta.com/products/prod2.htmhttp://www.teamdelta.com/products/prod2.htm would be perfect but you can also use something like this http://www.electronize.co.uk/switchers.htmhttp://www.electronize.co.uk/switchers.htm (the 2 way model) and couple it to larger external relays that can handle the current your motor draws.
  7. No sign of the Sabertooth yet, did you get round to sending it? Hope alls well.
  8. #9
