having read through the stats i dont see how the flipper weapon is going to work with the two discs and the shape of the robot. So in the stats i have come up with i have removed it.
NAME- D-J (Disc-tructive Jockey)
SHAPE- The shape is essentially the same a Shredder, except it is longer to fit in the extra set of wheels D-J has.
COLOUR- *add this your self tim*
WEIGHT- 100kg
SPEED- 18mph
TURNING CIRCLE- 0mm due to tornado style skid steer system
GROUND CLEARANCE- under the discs at the front is 15mm ground clearance, under the actual body at the front and the rest of the way round is 8mm. *if you wish add skirts to the sides and rear to make it 0mm*
ARMOUR- 5mm titanium
WHEELS- the robot has 8 wheels, although it only runs on for, it is set up in the same way as Big Nipper
POWER- 2 X 24 volt mag motors
WEAPONS- The robot has two discs, which are horizontal. The discs are horizontally next to each other, much like on Shredder. The discs spin in opposite directions inwards, i.e the one on the left spins clockwise and the one on the right spins anti clockwise, like on Shredder, it does more damage this way. It is powered on 36volt mag-motors spinning the discs at 3000rpm, it takes about 5seconds to spin them up to speed
SRIMECH- the robot is invertible
STRENGTHS- *find some*
WEAKNESSES- *find some*
there is some basic stats for you,
