Results 1 to 9 of 9
Thread: Chargering Nimhs
    hi all
    brought 2 8.4v 3300mah nimh battery packs. not chargered them yet, but the charger i have been using for my nicads is an Ansmann acs47 which i think can also charge Nimhs.
    has anyone had expierence with this charger, and therefore knows if it will charge Nimhs?
    also i i saw what looked like a very similar one on ebay which could charge both but for use with 1400mah-3000mah, just wonder if my current one does charge nimh whta would happen if it only went up to 3000mah, when my bats are 3300mah?
    thanks alex
    (Message edited by psycho fling on June 17, 2007)
  3. if i find out that it is a multi charger does this mean it will charge nimhs? hence multi
    alex
    thanks woody i did actually google it but i get nowhere or just dont put enough effort into it
    thanks alex
  7. erm.. instructions somewhere around but dont know where the reason for me asking
  8. #9
    Which Pro Peak one of these?
    http://www.active-robots.com/products/power-supplies/battery-chargers/o-ip2500vp-manual.pdf
    http://www.active-robots.com/product...ers/o-ip2500vp -manual.pdf
    http://www.ripmax.com/Images/PDF_Files/Instructions/Chargers/Pro_peak2500_Manual_LR.pdfhttp://www.ripmax.com/Images/PDF_Fil...eak2500_Manual _LR.pdf
    I suspect the answer is yes ...no matter which model you might have.
