Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Spektrum dx6
  1. #11
    But I still hate electronizes.
  2. #12
    If you have never used an expensive speedo, then electronize are good to use. but once youve driven with something abit better, you really notice the difference. What sort of budget are you on? this could wipe out the bulk of good speedos if its not very high.
  3. #13
    Leos right if you use the transmitter mixer you dont need a seperate one. We dont use electronizes ethier but many others do, allthough I should spell it correcly
  4. #14
    Funnily enough that is it spelt correctly Mark
  5. #15
  6. not in my previous post :sad:, Id expect Babeth to point that out
  7. #17
    Spektrum and Sidewinder is a terrific combo. You wont regret it.
  8. #18
    nope, even i like the combo :P
  9. #19
    Thats the setup in Little Hitter but we use 30V motors out of NuTool Drills, not sure maybe someone else can confirm but Id expect about the same performance out of the DeWalts ones so it should drive very well indeed with the right gear ratio.
  10. #20
