But I still hate electronizes.![]()
If you have never used an expensive speedo, then electronize are good to use. but once youve driven with something abit better, you really notice the difference. What sort of budget are you on? this could wipe out the bulk of good speedos if its not very high.
Leos right if you use the transmitter mixer you dont need a seperate one. We dont use electronizes ethier but many others do, allthough I should spell it correcly![]()
Funnily enough that is it spelt correctly Mark![]()
ok..... thanks for the advice...mmmm?..to much choice!i have decided to buy a dx6 from robo challenge,and a sidewinder from xbots... because i know you guys know what your talking about.
big question is can i have them on saturday and how do you want paying!!
not in my previous post :sad:, Id expect Babeth to point that out![]()
Spektrum and Sidewinder is a terrific combo. You wont regret it.
nope, even i like the combo :P
Thats the setup in Little Hitter but we use 30V motors out of NuTool Drills, not sure maybe someone else can confirm but Id expect about the same performance out of the DeWalts ones so it should drive very well indeed with the right gear ratio.
The gear box has 3 settings,so im hoping to be able to play about until I find the one i like.I think the ratios are,450/1500/2000.I will be driving a small gear of 18 teeth and then on to a larger gear of 40 teeth which will drive 100mm blue tyers.Im hoping to end up with a medium speed but powerfull pusher.The dewalt motors i guess should be more powerfull looking at the torque specification of 56nm dewalt against about 20/30nm nutool?.. I havent got a clue i realy,i just ask you guys!![]()
