Dont arse-kiss: do something about your stats, like actually changing them instead of leaving them the same and saying you changed them. :P
If your vapours ere sorted out Mark I might un-ban you from my tourneys
Mark, didnt you say that you were sorry before?
(Message edited by joeychevron on May 15, 200![]()
He did, hes just buttering up now.
ffffff>And I can say arse. Just like I can say ass. Its no swear word. (LISTENING, KANE? ARSE IS NO SWEAR WORD.) :P
(Message edited by kodster on May 15, 200![]()
Trojan/Virus/Worm (TVW for short)
Shape: Biohazard
Dimensions: 95cm x 65cm x 25cm
Weight: 100kg
Speed: 20mph
Ground Clearance: 0mm all around due to skirts, and 5mm without.
Colour: Black
Turning Circle: 0m
Locomotion: 4 solid rubber wheels mounted internally.
Power: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Armour: The skirts are 4mm titanium, while the body armour is 5mm Hardox.
Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
Srimech: Due to the power of the axe, the robot can easily self-right.
Notes: Has lots of shockproofing to prevent shock damage.
Minesweeper
Weight: 100kg
Shape: Tornado (S6)
Colour: Silver, with MINESWEEPER written on the sides in red.
Dimensions: 90cm x 85cm x 25cm
Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Armour: 6mm Hardox
Speed: 16mph
Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
Turning Circle: 0m
Weapon: 2 snowplow-like scoops that can move slightly vertically, like Behemoths, so I get good pushing power, but 0mm ground clearance at front and back.
Srimech: Invertible
Roveress
Weight: 100kg
Shape: Growler, with a pink bow on top of his head.
Colour: Brown, with black and white splotches in some places.
Dimensions: 100cm x 70cm x 40cm
Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 foam filled wheels.
Armour: 6mm Titanium/Vanadium alloy.
Speed: 20mph
Ground Clearance: 0mm at front, and 9mm everywhere else.
Turning Circle: 0m
Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-style barbs on it, the top Jaw, powered by a 2kg 1000psi Nitrogen tank, comes down with over 5 tonnes of force.
Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Dimensions: 100cm x 70cm x 30cm
Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
Armour: 5mm Hardox
Speed: 21mph
Ground Clearance: 0mm at front, and 5mm everywhere else.
Turning Circle: 0m
Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
Weapon 2: A flipping arm, powered by a 1.5kg C02 tank at 750psi. It can lift up to 250kg.
Srimech: The flipping arm.
Side Swipe
Weight: 110kg
Shape: Barberous 2 with tracks
Colour: Silver
Dimensions: 39cm x 90cm x 39cm
Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x C40-300 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 59cm x 10cm x 39cm titanium tank tracks.
Speed: 16mph
Ground Clearance: 0mm at front due to Sheer Heart Attack 2 style wedge, at sides due to skirts over the tracks. 5mm all around without wedge and skirts.
Turning Circle: 0m
Weapon 1: the Barberous 2 shaped body spins at 760rpm, powered by an S28-400 Magmotor.
Weapon 2: An 8kg Terrorhurtz style axehead, for use as a thwackbot weapon.
Srimech: Invertible
If you have any suggestions to make my robots lighter without reducing their quality, I would like them.
I replaced the LEM-200s on Armory with S28-400s.
I also decreased the damage potential on Tenderizer.
And removed one millimetre of armour from Side Swipe...
And decreased the size of the tracks a tiny bit...
and lowered the weight of the axehead to 8kg..
and removed 2mm of armour from Roveress...
and decreased the power of Cyriliums flipping arm...
and decreased the weight of the Co2 bottle powering it...
and changed TVWs skirts from 3.5mm Hardox to 4mm titanium.
..and increased TVWs armour from 7mm titanium to 5mm Hardox making it overweight...
...and did hardly anything about Side Swipe...
Want me to go on? :P
Sadly you didnt write...
And I decided to leave the forum...
Kody, are there any problems with my bots?
And here is the New TVW:
Shape: Biohazard
Weight: 100kg
Speed: 20mph
Colour: Black
Turning Circle: 0m
Armour: The skirts are 4mm titanium, while the body armour is 6mm titanium.
Does anyone have any suggestions for improving Side Swipe?
(Message edited by corsair_lightning on May 15, 200![]()
