Corsair
Weight: 100kg
Shape: All Torque (Series 2) with a wedge at the front.
Colour: Gold, with a blck stripe down the middle, and CORSAIR written on the sides.
Dimensions: 95cm x 70cm x 25cm
Drive: 4x S28-400 Magmotors powered by 5x NiCad Battlepacks.
Locomotion: 4 internally mounted fully Vulkanized rubber wheels.
Speed: 15mph
Ground Clearance: 0mm at front due to wedge, 5mm at sides and back.
Turning Circle: 0m
Armour: 5mm Hardox
Weapon: a 12mm titanium wedge, mounted on the front.
Srimech: an pneumatic flipping arm, built into the back of the robot, powered by a 1.5kg C02 tank at 750psi.
Armory
Weight: 100kg
Shape: Big rectangular prism with a wedge at the front.
Colour: Yellow, with blue on the top and bottom.
Dimensions: 90cm x 50cm x 30cm
Drive: 2x LEM-200 motors, powered by 5x NiCad Battlepacks.
Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
Turning Circle: 0m
Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
Srimech: Invertible
Tenderizer
Weight: 100kg
Shape: Imagine Hells Teeth, with a wedge on the front, and with Thors Hammer.
Colour: Black
Dimensions: 100cm x 50cm x 25cm
Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 2 Vulkanized rubber wheels at the front, and a caster at the back.
Speed: 19mph
Turning Circle: 0m
Armour: 8mm Titanium/Vanadium alloy
Weapon: A Thor style rack and pinion hammer, with a 2kg meat tenderizer for a hammer head,
powered by a 2kg C02 tank at 200psi, It can come down with about 1.25 tonnes of force, and easily pierce 6mm titanium.
Srimech: The axe can easily self-right the robot.
