Gimme 30 mins and I will have my lineup (and maybe a new robot...)
If there is another spot I will have my entrants up by tommorow
Team BriteSpark proudly presents...
Name: Supreme Glory Gamma
Weight: 100kg
Armour: 20mm Lexan and LexiGuard compound
Speed: 8mph
Shape: Pyramid shaped
Weapon 1: An 11kg Aluminium alloy axe powered by a 60v Etek, capable of generating 3Kj of force per hit.
Strengths: Strong armour and very manoeuvrable.
Weaknesses: Axe only works if something is in front or behind the robot.
Ground Clearance: 0mm all around due to skirts.
Srimech: The axe self rights the robot.
Notes: The robot is powered by 2 x 800watt 36v DC motors giving 8mph top speed. The 2 wheels are made from Ti/V alloy and coated in Vulcalore to aid in traction. The robot is covered in 20mm Lexan and LexiGuard compound. The axe weighs a total of 11kg and is shaped like Excaliburs axe from series 3 of Robot Wars. This shape is designed to focus all the force on a single point, meaning it can pierce through armour easily. The axe can give 3Kj of force per hit, roughly the same as Beta. The tips of the axe are covered in a thin layer of carbon, so if it fights a robot with Titanium armour, it can get through the armour even easier. To stop the robot from hopping about when the axe is fired, the robot incorporates a vacuum system. This can be switched on and off during a battle to allow for manoeuvrability and superior traction when static. The skirts on SGG are made from Grade 5 Titanium and are held in place by hinges.
Weight: 100kg
Armour: 4mm Grade 5 Titanium
Speed: 20mph
Shape: Low wedge
Weapon 1: A very powerful hydraulic crusher, with 14 tonnes of pressure at the tip.
Strengths: Very powerful crusher and strong armour. Good pushing power and good speed.
Weaknesses: Slow srimech.
Ground Clearance: 0mm at front due to wrinkler device. 5mm at sides and 1cm at back.
Srimech: It uses a set of Razer style wings.
Notes: The robot is powered by 2 LEM130 Lynch motors running at 36v, giving 20mph top speed and pushing power equivalent to 18HP. The robot has 6 inner Vulcalore wheels, which give tremendous traction. The crusher itself is made from 4mm Hardox, with 300 weight reducing holes. It is powered by an M-Mac M40 Hydraulic Actuator running at 12v, which can give 14 tonnes of pressure. The actuator has already been used in Robotic Combat, so this robot is realistic. The tip of the crusher is coated in carbon, so it can rip through Titanium easily. For the weapon to function properly, the robot contains 12 x 9.6-volt NiMh Radio Controlled Car Batteries, each weighing 12oz.
Weight: 100kg
Armour: 5mm Hardox all over.
Speed: Roughly 28mph
Shape: Box wedge with side skirts and rounded back.
Weapon 1: A linear actuator powered lifter running by a 4 bar system at 24v. This can lift 200kg easily.
Weapon 2: A small strip of Grade 5 Titanium on the front wedge, which gives 0mm ground clearance.
Strengths: Powerful drive and good strong weapon
Weaknesses: A bit too fast and hard to control when at full speed.
Ground Clearance: 0mm on front and sides, 1cm at back.
Srimech: Invertible, but can self right using the lifter if wanted to.
Notes: The robot is powered by 2 B42-500 MagMotors running at 60v. This gives Monsoon approx 60HP! The robot has a total of 6 wheels, 3 on each side. Each side is linked together by a set of heavy duty belts, giving 0m turning circle and the manoeuvrability of a 2 wheeled bot, and each wheel is coated in Vulcalon. The front wedge is angled at 42.5 degrees, meaning that it is not too steep or too shallow. The lifting arm is powered by a S28-150 MagMotor, and is made from 7075 Aluminium. The lifter itself can lift a total of 200kg, and can self right the robot if needs be. The side skirts are made from 4mm Titanium and are hinged.
Weight: 100kg
Armour: 10mm Aluminium Boron Carbite, with 5mm Lexiguard inside that to protect electronics.
Speed: 14mph
Shape: Invertible cylinder, like Barberous
Weapon 1: Spinning body which spins upwards, so it can flip its opponents.
Strengths: Powerful weaponry and very manoeuvrable
Weaknesses: Exposed wheels.
Ground Clearance: 7mm all around
Srimech: Invertible
Notes: The robot is powered by 2 C40-500 MagMotors with 4 36v packs and geared down 20:1, giving the robot a top speed of 14mph. Both wheels are based around Stinger, but have Vulcalore trims to aid in traction. The spinning body is made from 10mm Aluminium Boron Carbite, with 5mm Lexiguard inside that. The spinning body has Carbon tipped blades and Grade 5 Titanium blades attached all over it, so it can destroy all matters of armour. The body itself is powered by 2 LEM 130s running at 36v via 4 packs. This means the drum spins at approx 2500RPM. This should be enough power to destroy a robot in a matter of seconds.
Weight: 100kg
Armour: 1cm thick Hardox wheel hubs, 5mm Hardox axe head and 5mm thick axe pole. The axle joining the 2 wheels is made from 6mm Titanium and Vanadium alloy.
Speed: 28mph.
Shape: The robot is an axlebot based around Stinger.
Weapon 1: A momentum powered axe, which can come down with 800kgs of force.
Strengths: Hard to grab hold off and very tough armour. Great manoeuvrability.
Weaknesses: Poor pushing power.
Ground Clearance: 10mm.
Srimech: The robot is invertible.
Notes: The robot is powered by 2 LEM 130s, giving 28mph top speeds. The wheels are made from aircraft grade Aluminium, with Hardox wheel hubs and thick rubber treads. All the electronics, batteries and wiring are hidden inside the wheels. The 1cm thick wheel hubs should mean that nothing can damage the innards of Sonic Boom. To save weight on the robot, the wheels are only 20cm high, but are also 20cm wide, increasing traction on the arena floor. The axe head is modelled on Stingers axe from series 4 of Robot Wars, but is a lot tougher due to the 50cm, 5mm Hardox axe pole and 5mm Hardox axe head. The axe is momentum powered, meaning that when the robot stops moving from a charge, the axe swings over head and hits what ever is in front of it. This method of weaponry is not accurate most of the time, but when it does hit, it can cause a lot of damage. The 10mm ground clearance all over the robot should stop it getting stuck on arena obstacles.
Name: Pure Evil: Revenge of the Disc
Weight: 100kg
Armour: 7mm Hardox ring spinner and 4mm Titanium flipper/wedge.
Speed: 8mph
Shape: It is a ring spinner with a front wedge.
Weapon 1: The main body is a ring spinner made from 7mm Hardox, with Titanium teeth all over it. It is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. The disc weighs a total of 38kg.
Weapon 2: A spinning kinetic powered flipper, based on Team Whyachi€™s €œWarrior SKF€Â. It uses the kinetic energy from the disc to power the flipper, meaning it can flip with a total of 298KJ of energy.
Strengths: Unique and powerful weaponry. Good control.
Weaknesses: Takes a long time to self right due to the disc needing to spin up successfully.
Ground Clearance: 0mm at front and sides of flipper, 5mm at back due to ring spinner.
Srimech: The flipper can successfully self right the robot.
Notes: The robot is powered by 2 800w 36v DC motors giving 8mph top speeds. The wheels are made from Vulcalon, and have screws embedded in them to help gan traction on the arena floor. The ring spinner is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. There are 15 1€ cubed Titanium teeth all over the horizontal spinner, giving it 298KJ of energy on impact. The flipper works because there is an eccentric land on top of the spinning ring. The top link connected to the flipper plate has a groove in it, when fired the top link engages with the spinner land and pulls backward flipping the plate up. At the front of the flipper there is a 4mm Titanium €œnose€ with a sharpened edge designed to get under all skirts and ground clearances. All the electrics are kept within the 1m diameter of the ring spinner. This robot is based around Warrior SKF... videos on youtube to see what it can do.
Robot Name: Dennis The Menace
Length/Width/Height: 100 x 40 x 25 - 35cm (The height of the robot increases as you move from the front to the back).
Weight: 100KG
Motivation: 2 foam filled go kart wheels made of uber-tough rubber.
Speed: About 18mph
Weapon: The main weapon is a 20kg spinning drum, powered by 2 Huqsvarna 3120XP chainsaw motors. The weapon is capable of changing gears during a match. Originally, the drum spins at 2400RPM when geared down 10:1, but this can be increased to 2:1 at systematic intervals of 2 gearings (10:1, 8:1, 6:1, 4:1 2:1). The 4mm Titanium drum is fitted with 2 horizontal Hardox bars, welded, screwed and riveted on to avoid them coming off. These are designed not only to flip, but to rip off skirts and armouring. The drum can hit with over 10kJ of force when spinning at 2400RPM, and increases to an astonishing 243kJ when spinning at 2:1 gearing (12000RPM).
Drive: 24v Sinclair C5 motors.
Power: 4 x 24v NiCad batteries.
Armour: 5mm Titanium and Vanadium alloy.
Ground Clearance: 4mm all around.
Turning Circle: 0M
Notes: The robot is invertible, and is completely symmetrical when flipped, meaning the performance isn€™t altered at all. The robot€™s shape is basically a box, but with the height increasing as you move from front to the back. The robot has 2 thick Hardox spikes on each side, which means it can pass the passive weaponry rule, and these also stop the robot resting on its side. To stop it resting on its back, the rear of the robot is slightly curved.
And its latest creation...
Weight: 100kg
Armour: 4mm Hardox.
Speed: 18mph - powered by 2 Sinclair C5 motors running at 24v.
Shape: Box wedge with sloped sides, a rounded back and scooped front.
Weapon 1: A cam-driven axe mechanism, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
Weapon 2: A flipping arm, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
Strengths: Fastest axe mechanism currently around (hypothetically of course, this is only a vapour after all€¦)
Weaknesses: The weapon itself is not very destructive, but mainly shows dominance in terms of number of this it can do.
Ground Clearance: 0mm at the front due to a sharpened Titanium front and side skirts, 4mm at rear.
Srimech: Invertible, but the axe mechanism has enough power in it to right it back onto its wheels.
Notes: The axe-head is based on Dominator 2€™s, and has small Titanium spikes on each end to aid in self righting. The axe-head is make of Titanium, with a 5mm Hardox tip. The flipper arm is made entirely out of 10mm Aluminium. The robot has 4 wheels get up in a skid steer system and runs off 2 Sinclair C5 motors @ 24v. Each side is connected to each other by a heavy duty rubber belt, and the wheels are made entirely out of Vulcalore. The weapon systems run off a 60v Briggs and Stratton 11kW motor geared down 15:1. The motor is connected to a cam wheel which in turn moves the weapon up and down on its pivot. When running at 60v, the weapon can move just under 5 times a second. The emphasis is not on power, but in dominance and aggression.
Can you reserve me a spot? My internets down at home and I saved all my stats there - Ill send you in my stats when it gets better again.
Im writing this from school
Dont worry - I can bring in my team!
Well, Heres my group for Team Insanity
1.MeCANNIBAL 2.0
€ WEIGHT: 110kg (Shuffler)
€ ARMOUR: 5MM Titanium on top and bottom.
€ SHAPE: Invertible low cylinder
€ MOTORS: 2 x S28-400 MagMotors at 36V = 12HP
€ LOCOMOTION: 2 x Shuffling pads
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 20CM
€ COLOUR: Black with scary human face with over sized teeth coloured red.
€ WEAPONRY: Ring spinner, made of 8MM Harox, weighing 30KG, powered by 2 x LEM130€™s at 36V to give it spinning speed of 3000RPM and producing 195KJ per blow with a spin-up time of 3.5 seconds. It 2 big teeth made of Hardox that curve out. The teeth are inserted into the body and have rows of Tool Steel spikes on the teeth to dig in. These teeth 5kg each and are designed to send all the spinning energy into one spot rather than small amount into multiple spots. It also has 5 Inches worth of Titanium shock-proof Foam to stop it self-destructing.
€ SPEED: 15MPH
€ GROUND CLEARANCE: 0MM-8MM. It has a full-bodied 5mm Titanium skirt running completely along the ground that rises when the shell is spinning, but drops when the shell isn€™t spinning. This is powered by a simple 750w Bosch 36V motor and runs at the same time as the spinner.
€ STRENGTH: Scary name and weapon
€ WEAKNESS: Hard to control
2.AUTOISM 2.0
€ WEIGHT: 100kg
€ ARMOUR: 5mm Monocque Hardox on front, rear and top. 4mm Hardox for the Sides and Base.
€ SHAPE: Box with Pointed (Triangular) Sides and Rear to lower spinner Effectiveness.
€ MOTORS: 2 x Lem130 at 36V = 18HP
€ LOCOMOTION: 4 x Vulkaon treaded wheels on top and bottom ala Big Nipper. The wheels are now 85mm in diameter, giving better grip than before.
€ DIMENSIONS: (L) 75CM (W) 70CM (H) 25CM
€ COLOUR: Black for the body, Silver for the crushing weapon. Now, on top, it has the name €˜AUTOISM€™ written in silver.
€ WEAPONRY: The weapon for this is still a Big Nipper style crushing/lifting arm, but instead of claws to lift with, it has a pair of pliars to lift and crush with. The pair of 3.25mm Hardox pliars works on the same system as the lifter as the pliars are part of the lifter to avoid being torn out by spinners. The weapon lifts and crushes with a force of 9 Tonnes, using a Razer-like mechanism for lifting and crushing! The new crushing weapon means that if flipped, the robot doesnt need to self-right. The bottom part of the jaw is wider than before, to allow for more grip on the opponent
€ SPEED: 13MPH
€ GROUND CLEARANCE: 0MM - 8MM. 4MM Hardox sprung skirts on the sides and rear make it a nightmare to get under.
€ STRENGTH: Power and Weapons make it a tough machine
€ WEAKNESS: Weak side armour.
3.KNOCKING-OUT
€ WEIGHT: 100KG
€ ARMOUR: 5mm Titanium
€ SHAPE: Low box with a speed bump on top to give the axe a place to rest and prevent fast robots speeding over the top of me.
€ LOCOMOTION: 4 x Vulkanised wheels
€ DIMENSIONS: (L) 70CM (H) 26CM (W) 70CM
€ COLOUR: The body is black, and the skirts are silver with flames streaking off
€ WEAPONRY: An 8KG Terrorhurtz sytle axe, all made of Hardox. The head is blunted, and had Hardox spikes on the blades. It€™s powered by an 80MM 750PSI Bore ram. 2.5 tonnes of force at the axe. To protect it against spinners, 3 inches of Titanium foam is put in to protect it.
€ SPEED: 15MPH
€ GROUND CLEARANCE: 0MM-7MM. On the rear and sides are skirts made of 8MM Titanium. They are bolted down the middle with 1CM Titanium bolts. On the front is a fixed skirt, made of 5MM Hardox to get under things.
€ STRENGTH: Deadly to all Invertible robots.
€ WEAKNESS: Easily flipped
4.NITRO-GENE 4.0
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox for the body. 6mm Hardox flipper.
€ SHAPE: Low invertible box with pointed sides and rear. At the front is a Storm 2 style wedge to aid in getting underneath other robots. The scoop is now concave to slow down FBS robots and make them easier to fight.
€ MOTORS: 4 x LEM 130€™s at 36V = 36HP
€ LOCOMOTION: 4 Vulkanised Wheels.
€ DIMENSIONS: (L) 90CM (H) 17CM (W) 70CM
€ COLOUR: Black all over with the flipper coloured red.
€ WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a ratio 2.8:1, the flipper produces 1800kg of force at the tips, allowing me to launch anyone away! This version has 2 x 3kg Nitrogen bottles, giving me 25 flips!
€ SPEED: 22mph
€ GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the sides/rear, its 2cm. The orginal weakness of Nitro-Gene (its high ground clearance) has been seen to by the skirts on the sides/rear. They are 5mm Titanium skirts and are joined together like BioHazard - at the corners. To avoid them breaking off, they are held in place by Hardox hinges.
€ STRENGTH: Pushing power and weaponry.
€ WEAKNESS: High speed may mean difficult driving
5.TRI-TAINIUM
€ WEIGHT: 100kg
€ ARMOUR: 4mm Hardox for the back/scoop. The top and bottom panels are 5mm Titanium and the sloped sides are 6mm Hardox to sheild the wheels.
€ SHAPE: Low invertible box with a front scoop (the scoop has a slight dip in it to help get under other robots better) and sloped sides.
€ MOTORS: 2 x LEM 130€™s at 36V = 18HP
€ DIMENSIONS: (L) 60CM (H) 20CM (W) 60CM
€ COLOUR: Unpainted, with the exception of the name on top written in black paint.
€ WEAPONRY: The weaponry consists of 3 x 9kg discs, made out of 1cm of Titanium with 3 Hardox bludgening teeth. The discs are set on the same axle, and amounted deep into the scoop, with the teeth just reaching towards the lip of the scoop, so the uppercut movement of the discs can attack base-panels and the like. The discs are powered by 2 x LEM130s at 36V. Set on a ratio of 1.5:1, it gives off 3600rpm. The discs, combined together make 27kg, so the force given out is 165kj per hit! Large amounts of Rubber amounted behind the scoop stops the risk of self-destruction.
€ SPEED: 18mph
€ GROUND CLEARANCE: 0MM-1CM. At the front, it is completely 0mm. On the sides/rear, its 1cm.
€ STRENGTH: Weaponry.
€ WEAKNESS: Completely new design.
6.WORCK
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox for the body and flipper. 6mm Hardox for the scoop. There are wedges on the sides and rear of Worck made of 3.25mm Hardox.
€ SHAPE: A low wedge shape.
€ DIMENSIONS: (L) 70CM (H) 13CM (W) 70CM
€ COLOUR: Black for the flipper and barbs, white for the body.
€ WEAPONRY: A forward hindged flipper, running on a single 750psi ram running on CO2. The gas is contained in 2 x 5kg bottles, giving me 40 flips per fight, and the gearing on the ram 3:1 means we have 1300kg of flipping force! That should mean on a forward hindged flipper that I can flip almost everything OOTA.
€ SPEED: 13mph
€ GROUND CLEARANCE: The wedges make the ground clearance effectively zero, but underneath the wedges is 5mm of clearance. The wedges are held on
€ STRENGTH: Near impossible to get under.
€ WEAKNESS: Low speeds.
7.D.V.D (Death Via Drum)
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox.
€ SHAPE: An invertible box shape with triangular sides and rear.
€ MOTORS: 2 x LEM130€™s at 36V = 18HP
€ LOCOMOTION: 4 Vulkanised Wheels on top and bottom ala Big Nipper.
€ DIMENSIONS: (L) 70CM (H) 23CM (W) 70CM
€ COLOUR: Black for the drum, white for the body.
€ WEAPONRY: At the front is a 15kg drum, made of Titanium with 3 sharpened tool steel teeth. The drum is powered by 2 x LEM130€™s on a ratio of 1.5:1, giving a spinning speed of 6500rpm! 65kj of energy per hit, and if flipped, the drum can be reversed to help it spin the right way - upwards. Behind the drum, there are massive amounts of shock-proofing to avoid self-destruction.
€ SPEED: 13mph
€ GROUND CLEARANCE: The ground clearance is the same all the way around, due to no skirts or wedge - its 6mm all around.
€ STRENGTH: Good all-rounder.
8. A.R.R.T.D.S (Annoying Ramming Robot That Doesn€™t Stop)
€ ARMOUR: 7mm Hardox Monocuque.
€ SHAPE: Invertible box with flat front, sides and rear
€ MOTORS: 2 x C42-500 MagMotors at 60V = 60HP
€ LOCOMOTION: 2 x Shuffling Pads
€ DIMENSIONS: (L) 90CM (H) 15CM (W) 90CM
€ COLOUR: Black/White stripes
€ WEAPONRY: None.
€ SPEED: 28MPH
€ GROUND CLEARANCE: 0-5MM - Skirts on all sides made of 6mm Hardox prevent anything underneath any of the sides.
€ STRENGTH: Speed and power
€ WEAKNESS: No damaging weapons
Hope this is to your satisfaction, Tony![]()
Okay Ill enter my 2 vapourbots and 2 real ones.
Shape: Low box with front wedge.
Colour: Gold, skirts are silver, flipper is black.
Speed: 13mph
Armour: 5.5mm Hardox, and 5mm Titanium skirts. 8mm polycarbonate for the top and the underbelly
Drive: 2 LEM130s, 36 volts
Power: 6 NiCad Battlepacks, 36 volts
Motivation: 4 wheels, Vulkalon rubber on them
Ground Clearance: Wedge - 0mm. 6mm for the rest, but the skirts make it 0mm.
Dimensions: 80cm x 60cm x 20cm
Weapons: Rear-hinged low-pressure flipper, powered by 2 2kg CO2 tanks and a single pneumatic ram. Can flip 250kg and fires about 30-35 times in a fight. Can right it too.
Srimech: It runs upside down, or inverted.
Strengths: A really good all-rounder.
Weaknesses: First-time rookie: top and bottom armour vulnerable.
Shape: Very low invertible box.
Colour: Body cyan, skirts light green, disc white with grey teeth.
Speed: 12mph
Weight: 100kg
Armour: 7mm titanium, 5mm titanium skirts
Drive: 2 S28-400 MagMotors running on 24 volts
Power: 4 NiCad Battlepacks running on 24 volts
Motivation: 2 wheel drive, Vulkalon rubber on the wheels for traction
Ground Clearance: 5mm under side and rear skirts.
Turning Circle: 0
Dimensions: 105cm x 70cm x 10cm
Weapons: Horizontal disc running on 2 S28-400 MagMotors on 24v. The disc is made of hardox, has a diameter of 60cm and weighs 17.5kg. The two 15cm long teeth are also made of hardox and weigh 2.25kg each, so the entire disc weighs 22kg, and thanks to that KE calculator, it produces 97.64kJ. Has a spin-up time of about 4.5 seconds.
Srimech: Invertible.
Strengths: Destructive weapon, good all-rounder otherwise.
Weaknesses: Tires can be hit by axes and crushers, high spin-up time for disc.
Real ones:
Razer (S6)
Typhoon 2 (S7)
Turbulence (most recent)
Tornado (S7)
Dantomkia (most recent)
Hexadecimator (RoboGames 2006)
I said I would CONSIDER realies, not allow them...
Really, I dont care much for it because A: I dont have accurate stats for them on hand, and B: It takes away some creativity, imo.
The Welsh Warlords:sadimensions are lxwxh cm)
Brutalis 1.0
Weight:100kg
Shape:Like Dantomkia, but much lower and heavier at the front
Dimensions:90x90x25
Power:2 x S28-400 Magmotors powered by 2xNIcad battlepacks
Drive:2x go-kart wheels
Armour:4mm thick hardox, 3mm base
Weaponry:1000psi rear hinged nitrogen power flipper, 2 x3kg bottles, 2 x 65mm rams
Ground Clearance:6mm behind skirts which cover the rear and sides.The flipper covers the front end.
Turning Circle![]()
Srimech:The flipper
Colour:Black all over with yellow flipper and red skirts, name painted in luminous green on the rear
System Shock
Weight:100kg
Shape:Think Panzer from Robot Wars 3, but with side skirts around the sides and rear
Dimensions:80x80x20
Power:4 x LEM130s running at 36v
Drive:2 x tank tracks, like the ones seen on the army robot Rhino
Armour:4mm thick hardox all over
Weaponry:Tornado-style static wedge
Turning Circle:0
Srimech:Invertible
Colour:Light blue with the name painted in yellow on top and bottom.Skirts are painted yellow and black stripes
Henry VIII
Weight:100kg
Shape:Like Sumpthing but with protected wheels and a scoop instead of prongs
Dimensions:80x80x35
Power:2 X S28-400 Magmotors powered by 2xNIcad battlepacks
Armour:5mm thick titanium on top and sides, 3mm thick titanium on base
Weaponryiamond edged axe powered by 2x 3kg Co2 bottles running on 750psi, static scoop constructed from titanium
Ground Clearance: 5mm all around, but scoop makes it effectively zero at the front.5mm behind the scoop
Turning Circle![]()
Srimech:The axe
Colour:axe is painted gold with a red tip, the main body and scoop are painted light blue
5 more to come, but are realies allowed or not?
I duno why those clip arts have turned up in my previous post, as I didnt put them in!
The turning circle for Brutalis and Henry VIII is zero, and ignore the one next to my team name!
: O (without the space) =![]()
: ( (without the space) = :sad:
I think thats part of your anwer Liam![]()
