Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 115
Thread: NSIREC2
  1. #11
    Shape: Low box-wedge, with slightly sloping sides which will prevent the robot landing on its side.
    Motivation: it uses four Vulcalon wheels (storm 2 like)
    Speed: 14 Mph
    Weight: 98kg
    Height: 28cm
    Length: 90cm
    Width: 75cm
    Weapon: On the front of wedge and up the top of the box, is a low-pressure pneumatic front-hinged flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This should have no trouble flipping the heaviest robots. The flipper can easily selfright the robot.
    On the back of the robot is a 500mm horizontal flywheel spinning at 3000rpm. It has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second.
    Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
    Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
    Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
    Color- The main bit of the robot once again is blue, the disc is still yellow.
    Clearance- Under the wedge it is 0mm, under the sides it is also 0mm due to the skirts but 5mm with out them. Under the rear there is 5mm under the disc it is 10mm.
    Strengths: Powerful weapons, low ground clearance
    Weaknesses: New design
    Notes- New design after being trashed by spinners, hopefully can work as well as Disco 5 despite changing the disc from vertical to horizontal
    Name- Take me out (thanks to Dave for naming the robot for me)
    SHAPE- Wedge
    COLOUR- Dark grey
    WEIGHT- 100kg
    DIMENSIONS- Height: 20cm, Length: 80cm, Width: 65cm
    SPEED- around 18mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- 0mm at the front due to wedge extender, 5mm at sides and rear
    ARMOUR- 4mm Aluminium Boron Carbite
    MOVEMENT- 4 inner vulcalon wheels, it uses a skid steer system like tornado
    DRIVE- 2 LEM 130€™S on 36 volts
    BATTERIES- custom 3300mAh NiCad Cell 36v BotPack
    WEAPONS- The robot has a 1000psi nitrogen flipper on a 80mm bore on a 100-stroke ram which should make around 3.5 tones at the ram (if I am incorrect please correct me) the nitrogen is stored in 2, 2.2kg canisters, the robot has around 25 flips in a fight, the flipper is on high pressure
    STRENGTHS- Powerful weapon, good drive
    WEAKNESSES- limited supply for the weapon
    Name- Panicking (previously panic 3 GTI 2)
    SHAPE- Low invertible box
    COLOUR- Yellow except for the lifting forks which are black
    WEIGHT- 98kg
    DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
    SPEED- 23mph
    TURNING CIRCLE- 0 mm
    GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
    ARMOUR- 12mm polycarbonate
    MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
    POWER- 2 x LEM130€™s on 36 volts
    WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
    STRENGTHS- Low ground clearance, reliable weapon
    WEAKNESSES- previously lost to spinners
    NAME- Call out hook (thanks to Matty. H for help with the weapon description)
    SHAPE- low box wedge (like storm 2 but not invertible)
    COLOUR- white
    WEIGHT- 100kg
    SPEED- 23mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
    ARMOUR- 4mm hardox
    WHEELS- 6 inner Vulcalon wheels
    POWER- 2 x S28-400€™s Magmotors on 24v.
    WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
    SRIMECH- the lifting arm which can self right from any position due to the turret
    STRENGTHS- good weapons, good pushing power
    WEAKNESSES- if the arm is spinning round slowly it may topple
    NAME- Happy birthday party pooper (previously Birthday party pooper) (ta to frank for the help he gave me with finalising this robot)
    SHAPE- invertible disc (like gyrobot)
    COLOUR- Blue
    WEIGHT- 145kg
    DIMENSIONS- 100cm diameter X 20cm height
    SPEED- 10mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- its about 10mm but 3mm under the blades
    ARMOUR- 10mm titanium body
    MOVEMENT- it runs on 8 inner anarchy style legs.
    WEAPONS- it has a powerful spinning shell spinning at around 1500rpm weighting around 75kg powered by 2 X LEM-130s running at 48v, it has 12 typhoon2 style teeth around the out side 4 around the bottom 4 around the middle and 4 at the top
    NOTES- all components have been shock proofed with rubber around them.
    STRENGTHS- very destructive weapon
    WEAKNESSES- easy to push if weapon not spinning
    NAME- The deer (was crusher chaos)
    SHAPE- Invertible box
    COLOR- the robot and claws are a dark green color
    WEIGHT- 100kg
    DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
    SPEED- 15mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear due to the skirts, without skirts 6mm. The skirts also work both ways up.
    ARMOUR- 3.6mm hardox
    MOVEMENT- 4 inner wheels that make the robot invertible
    POWER- 2 x S28 Magmotors on 24v.
    WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers (shaped like those you find in extreme destruction.) The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
    NOTES- invertible, wide base means the deer wont topple while crushing
    STRENGTHS- Very powerful weapon
    WEAKNESSES- it could be turned into venison
    Name-Forklift 2
    SHAPE- Low box with rear anti self flipping wedge
    COLOUR- Yellowy orange
    WEIGHT- 100kg
    SPEED- 18mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
    ARMOUR- 3mm hardox
    WHEELS- has 6 inner storm 2 style wheels
    WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
    SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
    NOTES- this is a modified version of my robot from the panic attack forum.
    STRENGTHS- Power full weapon
    WEAKNESSES- limited co2
    NAME- Star 69
    SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
    COLOR- yellow
    WEIGHT- 100kg
    SPEED- 19mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
    ARMOUR- it has 4mm grade 5 titanium
    MOVEMENT- it uses 6 inner storm 2 wheels
    DRIVE- it uses 2 x lem 130€™s
    BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
    WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots and also used for bottom teeth when flipped
    SRIMECH- Invertible, points and blades stop it from sticking on side
    NOTES- according to frank the name is rude, first star shaped robot
    STRENGTHS- Powerful weapon and drive
    WEAKNESSES- nights with no stars
    any problems just say so
  2. #12
    I wanna enter, hell yeah, but I still havent got 8 realies at my disposal
    and I shall not reserve a place when I know many more excellent roboteers (Steve?) can enter 8 vapours right away
  3. #13
    swiss_tony
    Guest
    Actually, I miscounted. We were at 5 before, now at 6 with Martyn.
    And ok Martijn
  4. #14
    Martijn, get on MSN some time, and Ill help you with some stats.
  5. #15
    swiss_tony
    Guest
    Alex M? Frank? Aaron? Anybody?
  6. #16
  7. #17
  8. #18
  9. #19
    Minumum speed is 3 MPH... so it cant stand still?
    Im sure thats against the safety rules Timmy :P
  10. #20
