Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
Thread: AJWars: A New Era...
  1. #21
    davids
    Guest
    Does anybody remember the url of the forum I used to keep my stats?
  2. #22
    I think Liar will do
    http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
    if not... please tell me soon :P
  3. #23
    Colour: Natural colour of the materials - so realisitcally grey/metallic
    Shape: Cylindrical (like tengu, but with a greater upper taper)
    Weight: 100kg
    Power: 3 x C40-500 MagMotors at 36v
    Wheels: about 20cm diamter and 4cm wide, cast aluminium with a rubber tread with small studs extruding 1mm from that for traction
    Weapons: A true full body spinner - ie. spins on its wheels to get the full mass behind it, however, the blades are somewhat unusual - they are shaped so that in one direction it forms a wedge that skims just above the floor and curls upwards which should hopefully get beneath a robot and turn it over. On the back of these are blunt stainless steel blocks for a more traditional usage of its full body spinner power. Essentially if it spins oen way it is a flipper, the other it is a damaging FBS. The twisting motion of the wedges and their rigidity should help it get beneath even very low robots.
    Turning Circle: 0m
    Armour: 6mm kelvar over 3mm titanium.
    Strengths: Tough and various means of attack.
    Weaknesses: Has to be able to spin to do much.
    Srimech: A longer version of the hynodisc srimech inset into the top perpendicular to the blades. Essentially a trimmed down tengu srimech.
    I have no idea if that will even work - I can do a render if wanted.
  4. #24
  5. #25
    davids
    Guest
    Thats the link Andy, I knew it was farr, but couldnt remember the proboards number.
    I shall enter Quocunque Jeceris Stabit, as its nice and simple.
    Stats:
    Team - The Unforgotten Sons of Eden.
    Shape: Simple wedge, with side bumps and a curved rear.
    Colour: Blue
    Weapon: A Chaos 2 style flipper with rams etc, I don€™t want to go into detail here, because it will make the stats long.
    Armour: 5mm aluminium, with little titanium protection strips around the sides and a titanium strip, simpler to Firestorm 5 at the front.
    Speed: Top speed is 25 mph, but I like it best at around 14 mph.
    Weight: 96 kg
    Ground Clearance: Close to zero at front, sides and rear the ground clearance is 2cm for better turning.
    Motors: 2 Bosch 750€™s at 24 volts.
    Wheels: 2 wheels, designed to give grip on most arena surfaces.
    Srimech: Flipper, at a lower pressure.
    Strengths: Flipper will keep going whatever you throw at it
    Weaknesses: A bit out-of-date with today€™s standards (that was in 2005
    Those do Andy?
  6. #26
    Yep - a translational spinner.
  7. #27
  8. #28
  9. #29
    Just need a few more days to work out the parts and finish the render :P Also need a name for it....
  10. #30
    Call it.... errr.... Aaronbot..... or, errmmm.... Mad Explosion! or..... Fission or...... some kind of Australian themed name....
    I suck at naming other peoples robots (and arguably my own) but as I dont even know what its like I cant really go with a theme.
