Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Decent motors
  1. #31
    BonX uses spur gears, single stage 1:6 reduction speed 900, 23 mph and enough power to sit on and drive around.
  2. #32
    quote:
    how do you gear a motor? this is probably a rookie question but i have never had to do it!
    Alex, Jamies post above is really useful, I must say.
  3. #33
  4. stu's Avatar
    Member
    And bent axel shafts
    Mr Stu
  5. #35
  6. Good point actually Geoff, I remembered the Astros went through the gearboxes first but forgot that you used spur gears to take the drive to the rear wheels. Timing belts were the most obvious parts to see in pictures etc which is probably why I forgot about the rest!
    Still, it is a very sexy 6WD machine...........when its got all six wheels attached that is :wink:
  7. #37
  8. if i were to go for the chains and sprockets, what size stuff would i need?
    alex
  9. #39
    Alex I use the 6mm pitch chain and sprockets from Technobots. Have a look at DB5 next time you get a chance, I use a mix of spur gears and chains.
