Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Running problems
  1. #11
    which speedos are they?
  2. #12
  3. ok ill translate, the motor was moving as if it wasnt failsafing kind of way, but the tx was on. after this had stopped i tried moving it using the transmitter and nothing happened, like before i went to basics this any better?
    speedos electronize
    Ill try that woody and post later
    thanks for the help so far
    alex
  4. #17
    ok if doing the suggested do you need am servos for a am transmitter and do they need to be the same make?
    i have tried it with some which arent as above and nothing so..
    what would be the next stage after this if it does work?
    cheers alex
  5. #18
  6. Another thing that everyone has done on here at some point and havnt worked out for a long time...
    Are you sure youve plugged the leads from the servo/speedos in the the right way around?
    If not the battery that your plugging into the receiver may not be charged, may be a loose connection in the battery (very common in receiver packs so check that voltage first. If your getting a voltage through the battery, and its plugged in the battery pins, the correct way around and all other leads in the correct way around then you have a problem with your tx/rx. If thats the case, then check with a differentset of crystals, then can stop working if theyve had a knock.
  7. #20
    ok answers to the questions
    Woodys
    yes it did work before at wigan in a way, but since then it hasnt worked
    the transmitter is showing full(green)
    we are using the battery box thing that comes with the transmitter, and using 4 AA
    yes we do have a spare transmitter reciever crystals because we have another transmitter setup exactly like this one
    Grant
    I will checkthe connections but im 99% sure i have checked them, and they were ok
    i will try the different crystals, and the leads and post later
    cheers alex
