Page 55 of 68 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 680
Thread: The Crash & Burn Tournament 2
  1. #541
  2. #542
  3. #543
  4. #544
  5. #545
    Terrorhurtz doesnt have a suction device, it uses a pneumatic foot at the back to push down and try to counter the front lifting. It was Killerhurtz that had it, Ive got an old video of John Reid driving it upside down The issue was the moment you break the seal of air between the floor and the robot, you lose the down force.
  6. #546
    Let€™s finish it up, gentlemen.
    Heat P Final
    Clawdius Decimus Murderous (2) vs. Infusion
    It was a tough break for Black Panther Queen, as both competitors managed to overcome it in a judges€™ decision. Clawdius Decimus Murderous (2) afterwards decided it was bye-bye for Terror Gear 3, and Infusion gave The Crashing Bore a reason not to bore people anymore.
    Roboteers, stand by...
    Booth 1: Clawdius Decimus Murderous
    Booth 2: Infusion
    Taki-san? Check. Tira-san? Check. Pure dose of pain? Wouldn€™t leave home without it.
    3...
    2...
    1...
    ACTIVATE!!!
    Quickly Clawdius blasts off the mark, desperate to try to stop that spinner before it reaches speed, but noooope, Infusion€™s got the rim at speed now, and turns to use it in full force. Now Clawdius slows down, very tentative, unsure of how to approach the rim. Aaron senses weakness, and Infusion charges offset towards the sides. Clawdius backs off a little, taken aback a little, but repeats The Crashing Bore€™s strategic €œkeep-the-front-pointed-at-him€ tactic. Infusion stops, and Clawdius suddenly rockets out towards Infusion, exactly what Aaron was expecting. Infusion reverses gears, and goes forward, away from Clawdius, as the 2nd seed moves in front of him. Perfect! Infusion takes him to the cleaners.
    CRASH!!!
    Once again, we are another €œun-skirting€, as Clawdius now has his right side completely defenceless. Infusion tries to turn around and dash for the side but Clawdius has the front pointed at him again and advances on him. Not wishing to become pit fodder, Infusion moves away and dashes around the arena, getting the rim back up to speed. Clawdius hurries in, regardless, and rampages towards Infusion, trying to catch him off-guard. Infusion is a little late to get away, and the rim bumps against Clawdius€™ wedge...and on the side of it!
    CRASH!
    A nice dent is put into the frontal side...and actually bending the wedge a little! Aaron beholds it quite clearly, and Infusion rockets towards Clawdius, wedge-first, slamming into the 2nd seed, and the effect is expected: Clawdius€™ bent wedge and extender are unable to protect him against Infusion€™s own wedge, and scooped up onto the wedge Clawdius is taken right to the wall! WHAM! He bounces up over Infusion...and into the rim!
    CRASH!!!
    It€™s the skirtless side that takes the blow, and another dent is caused, though not really inflicting much more damage. Clawdius is thrown back, and Infusion backs up, turns, and flies at Clawdius, who can€™t seem to get out of the way in time, and instead turns to give Infusion the other side skirt. It€™s unfortunate for Steve, though, as a Kinetic Boost-fueled Infusion slams into the skirt with such force that the skirt actually flies up! Infusion turns around again using the rim to deal the falling skirt a blow.
    CRASH!!!
    The already weakened skirt is torn right off and lands with a clatter at the opposite end of the arena! Not looking good for our runner-up, I daresay. Clawdius, valiantly, makes his way towards Infusion, who just blazes a path towards him, gets under that sad and slightly bent wedge, and gives him another taste of cold, dead arena wall. WHAM! This time, Clawdius is not bounced off Infusion€™s wedge, but stays stuck there, pinned against the wall. Infusion tries to turn and scoop Clawdius off the wall but obviously it€™s not working because Clawdius is staying right where he is, and that would be on that spot on the wall. €˜Screw this€™, Aaron says to himself, and turns Infusion around again.
    CRASH!!!
    Clawdius gets nailed by the rim once more, but this time the rim doesn€™t appear to have inflicted damage. Clawdius is definitely living up to the team name €œBraveheart€, but how much good it€™s doing him, I can€™t guess, as he comes towards that devilish Infusion. Infusion wedges him again, but does not throw him into the wall. He€™s going to give Clawdius a trip to Taki-san€™s CPZ! As if this is some sort of signal, Taki immediately turns around and gives our beloved 2nd seed a nasty hit with the cutting blade!
    CRASH!!!
    That€™s all she wrote for Clawdius€™ skirts, it seems, as the rear one is now separated from Clawdius€™ high rear wedge. Infusion pushes him further into the CPZ and Taki is smushed into the corner. That€™s the cue for Tira-san to join the insanity and she comes zooming out. Infusion hurries away as Tira flies by, and Clawdius can€™t seem to get by the incoming house bot!
    CRASH!!!
    One of the two €˜spears€™ gets the axe, or rather the blade, as it goes flying. Infusion goes after the pit release button, pretty much knowing how this battle is going to end up. Clawdius is now sandwiched between the house bots and Infusion goes back to get him out of it...a tackle to Tira sends her tilted into Clawdius, who still seems to be moving, and finally is away towards the flame pit. Infusion releases Tira and once again pursues Clawdius around the arena. Clawdius again gives Infusion the front wedge, but it€™s quite futile by now, as Infusion scoops him onto his own. Infusion carefully lines Clawdius up with the pit, aaaaaaand...BOOM! HAHA! Infusion went a little too fast and put himself in too! Aaron gives the audience the €œI-don€™t-wanna-hear-it€ hand sign.
    CEASE!
    Clawdius Decimus Murderous had come, was seen, and was conquered.
    Infusion advances to the Series Semi-Finals!!!
    So, our Semi-finalists are...
    Salamander III (1)
    The Disc 5
    Aquarius (5)
    BIACS-LE
    Killotine: EVO (9)
    Tengu VII
    Axeon (13)
    Cyclone Force 2.5
    Cosmic Thunder 2
    Tempest Evil-er-oution
    A Night at the Bar
    Flank Attack: DT
    SUNCUST
    Son of Ripper 5.0
    Sheer Heart Attack
    Infusion
    Line-ups will be up next post. And w00t, 2000 posts. I officially have no life.
  7. #547
    +1>The Crash & Burn Tournament 2 - Semi-Final Line-ups
    Semi-Final 1
    Salamander III (1) vs. Axeon (13)
    Killotine: EVO (9) vs. Cosmic Thunder 2
    A Night at the Bar vs. SUNCUST
    The Disc 5 vs. Infusion
    Semi-Final 2
    Son of Ripper 5.0 vs. Tengu VII
    Tempest Evil-er-oution (14) vs. Aquarius (5)
    Cyclone Force 2.5 vs. Sheer Heart Attack
    Flank Attack: DT vs. BIACS-LE
    Tactics, predictions, comments, thoughts, and Roman candle so I can kick off this semi-final with a big BANG. Please.
  8. #548
    Nah, it would have been a http://lh4.google.com/erin.michael/R...?imgmax=512Too
  9. #549
    Semi-Final 1
    Salamander III (1) vs. Axeon (13): A very tough first battle - Axeon has 6mm Hardox armour, extreme power and speed - however, it doesnt mention ANY shock-proofing in the stats. Salamander might dont be the quickest of any robots, nor the most damaging, but it has very sharp teeth and very good staying ability. For this match, Ill go for the champ.
    Killotine: EVO (9) vs. Cosmic Thunder 2: Could go either way for this battle, but I think it looks bad for the Lexan armoured Cosmic Thunder. If Cosmic gets under Killotine and pushes him towards the wall, and can flip, then Alexll win. But I believe Killotine to impale Mr McW and pit him.
    A Night at the Bar vs. SUNCUST: A bad draw for ANATB. SUNCUSTs armour might be too thick for the bar to do anything. Unless it hits something important, the retired Antony will win through a pitting.
    The Disc 5 vs. Infusion: This is going to be a SUPER battle! But The Disc 5 is well-known for being difficult to kill. Thats why Im going for him to win.
    Semi-Final 2
    Son of Ripper 5.0 vs. Tengu VII: Tengu VII win because...ITS TENGU!
    Tempest Evil-er-oution (14) vs. Aquarius (5): A bad draw for Tempest - Aquarius to use its speed and power to bash underneath and flip it out!
    Cyclone Force 2.5 vs. Sheer Heart Attack: Assuming Cyclone Force picks the claws, it can grab onto the sides of SHA, and slam him about. But Ill have to wait for the set-up Chris chooses first.
    Flank Attack: DT vs. BIACS-LE: Flank Attack might be a well-known killer of spinners, but BIACS-LE is very wacky, and if that disc gets a blow on those exposed tyres, game over for Flank Attack.
    Those are my predictions, so... *Hands Kody 100 Roman Candles to start if off* :wink:
  10. #550
    Not going to be an easy battle for either of us. Damage is not going to be the winning factor, more likely control and aggression. Will ponder some more on tactics, and probably revise TD5s stats a few times....
