Results 1 to 9 of 9
Thread: Fiberglass
  2. #3
  3. #7
    If my Knowledge and memory allow
    For Casting
    Create smooth template.
    Creat wooden box horizontally cut in half.
    Use liquid (forget name - to stop pieces sticking together)to coat template
    Insert rubber mixture into bottom box
    Insert template
    Leave to dry
    Recoat exposed template in liquid
    Insert rubber mixture into top box
    Lower upside down bottom box onto top
    leave to dry
    when all dry release the mold
    Though for an RC car shell you may only need the top half!!!
    For duplicationwith fibreglass
    Coat the top/bottom mold interior with above liquid
    Start laying out Fibreglass sheet with Epoxy resin when all points are done leave to dry
    Remove fibreglass copy
    Glue halves together if needed.
    Though Ive never tried this, thats what I think happens in some cases. Constructive criticism please.
  4. #8
    If you do several layers for added strength put the weave of the next layer at a 45 degree angle to the previous one.
  5. #9
    Sorry, just doublechecked it - What I said was a resin cast.
    I put the error on dividing my attention between my signal processing assignment and this.
