Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: New Blood... New Beginning...
    Ladies and gentlemen, the latest disasterpiece from Team Braveheart!
    NAME- The Riddler
    SHAPE- bowler hat with a small scoop shape at front and back
    COLOUR- green with a white band, purple question mark at front
    WEIGHT- approx 100kg
    DIMENSIONS- 90cm X 90cm X 35cm
    SPEED- 15mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- approx 0mm for scoops, 8mm all round elsewhere
    ARMOUR- 4mm Grade 5 titanium
    MOVEMENT- 4 inner wheels
    POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
    WEAPONS- 180 degree pneumatic axe with twin heads, appears similar to a walking cane. It is powered by 2 x CO2 tanks running at 160psi and uses the rack-and-pinion mechanism. Hopefully, the hammer can produce between 30-40 blows per fight.
    SRIMECH- the axe
    NOTES- flies the Scotland flag
    STRENGTHS- fast and manouverable, a mighty thwack, good pushing power
    WEAKNESSES- possible spasms, limited blows, average armour for the Hardox Age, stats may be complete rubbish
    Piccy here: http://img296.imageshack.us/img296/3128/theriddlervapourbotza1.pnghttp://img296.imageshack.us/img296/3...pourbotza1.png
    Hope thatll do, Mr J and welcome back to Bedlam!
    (Message edited by Steven_McG on December 24, 2006)
    amazing Andy, please reserve me a spot
    Ooh.....hold me a spot....I need to get my creative brain in gear....
    Ill steal a spot. Since hardly any of my vapourbots are new and many of them havent competed...I think Ill enter Entropy. Stats can be found on my forum:
    http://strickenone.proboards99.comhttp://strickenone.proboards99.com
    If you need stats posted here, then Il do it. Cheers!
    NAME- Dakkon
    SHAPE- Difficult to describe - think a smooth Sumpthing with a front scoop. Ill try to knock up a picture.
    COLOUR- A greenish-grey with flecks of silver
    SPEED- 18mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- Zilch for front as is has a titanium strip, the rest varier at over a centimetre
    ARMOUR- Front plate is 6mm hardox, the rest however is 7mm aluminium over a titanium chassis.
    MOVEMENT- 2 large wheels behind the front plate, again similar to Sumpthing.
    POWER- 2x 750 watts Bosch motors at 24v.
    WEAPONS- A huge single edged pnuematic axe - the recoil is only enough to self right it, and the blade is a quarter circle and weights 5kg, with sections cut out of it to decrease weight. It works similar to terrorhurtz - ie attempts to mash things apart, but only in one direction. It uses four canisters streamed into the piston to produce its power.
    SRIMECH- The axe does it all - there are side struts from the shaft to aid it in this.
    NOTES- Other than having a bizarre shape isnt very creative for me - but there again I havent had any losses to react against with my scheming
    STRENGTHS- Powerful, decently fast, the front armour should protect it from spinners
    WEAKNESSES- Back vulnerable to flippers and most things, will probably dance like terorhurtz a bit, axe could get stuck in certain things like wood.
    Ill need to make up a picture of it, which Ill do this week with any luck.
