Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Feather weight robot build question
    Hi all,
    This is my first post here, so be gentle :-)
    I was at the leicester space center on the weekend and had the fortune to see a combat robot demonstration. This has kind of re-ignited my interest in the whole robot wars thing. My son is now at an age where he can join in and is also interested - with my son on side, I finally have an excuse to build my first combat robot.
    I intend to build a fairly simple ram bot for the feather weight class, but would like to get some opinions before I start buying bits and putting the thing together. It would be made from steel tubing and armour, using aluminium internally where possible for other things like motor mounts etc. to keep the weight down.
    Anyway - here are my questions
    Motors and gears
    obviously, rambots rely on speed so the right combination of motors and gearbox/transmission is important. What sort of motors should I aim for? I see drill motors touted around the forums as a cheap way to move a robot, but would they be any good in a rambot? Also - Gearboxs / transmission. Should I be aiming for motors with gearboxs, building my gearbox or would a simple chain drive be the best option?
    Speed controller
    Advice please - which make to go for..?
    Radio Gear
    27mhz or 40mhz 2 or 4 channel?
    Rambots and anti-shock/vibration
    If the mechanics are sufficiently secured, is this nessasary - are the magnets in
    the motor likely to fall out? How are the electronics affected.
    I want to build a robot that is competitive, so any advice would be appreciated.
  2. Greetings Peter,
    Glad you enjoyed the Space Center event, before you start anything please download and read the FRA build rules....
    http://www.fightingrobots.co.uk/documents/buildrules2006.pdf
    http://www.fightingrobots.co.uk/docu...drules2006.pdf
    These will answer a lot of your questions regarding things like radio, allowable battery types, etc etc..
    Once you have got your head around the rules, Im sure there are plenty of people on this forum who will be more than happy to point you in the right direction.
  4. Hello Peter,
    As far as radio is concerned, 40Mhz is the only option, as long as the Spektrums are not legal yet, and for a rambot you can make do with 2 channels (forward/backward 1 channel, left right the other), but if in a later stage you want to make a remote controlled weapon, a third channel would be needed, so its better to start off with 4 channels so you are set for the future.
    As for speed control, there are various flavors, all in different priceranges. The best in my opinion are the sidewinder and the mini vantec, but Electronize and Mtronik also are very nice.
    As for power, you can go to obscene amounts of power in a rambot, but if you cant get that power to the floor, it is of no use. So make sure you get some good wheels to match the drive train you want. James already posted some good expamples.
    Have fun building and battling.
    Hi there Peter - glad you enjoyed the event at the Space Center, the amount of positive feedback weve had from it has been overwhelming !
    If youre starting out Id suggest starting at the simple end of the scale. Youll want gearboxes and motors that come as integrated units - all you need to do is fit your wheels on. Cheapest source of these are cordless drills http://www.gimsonrobotics.com/electricmotors.html
    http://www.gimsonrobotics.com/electricmotors.html is a good source, most expensive source is http://www.robotcombat.comhttp://www.robotcombat.com (Astroflight 940Ps). Either way start simple, you can always upgrade later.
    Speed controller - for out of the box usage Id reccomend a Sidewinder which you can buy from James Baker above. http://www.robotpower.comhttp://www.robotpower.com for details on that.
    Radio gear - yes 40Mhz is the way to go.
    As for shock mounting, yes youll need to think about the shocks but for a general rule make sure you can pick your robot up by any other part of the robot (and that includes batteries, motors and speed controllers). If you can do that you should be on the right road.
    Youre bound to get plenty of information from the builders around here on what to do !
    Welcome to the family
    Ed
    http://www.teamstorm.comhttp://www.teamstorm.com
    As mentioned above really, drill motors are a very simple an very effective source for drive. Ewan Gimson sells them at a good price, and he overvolts them in his robot at 18v giving him a very good reliable system (using the sdewinder speedcontroller). I guess you are looking at 4wheels drive? If so, then the simplest method of using all four wheels is probably to use four motors(wheels directly onto the motor gearbox)-espcially when a set of pulleys can cost more then the motors!
    I would recomend using a 4channel 40mhz transmitter (futaba is always a good choice)as this will give you the option to add a weapon at a later date.
    almost everything except the motors are now shock mounted in my robot, using rubber gromets for speedcontroller/baseplate mounting, and neoprene(or any good rubber/foam) for surrounding my batteries. Since i did this my robot has become MUCH more reliable.
    Good luck
    I shall be getting my act together with the new Gimson Robotics website asap which will stock a range of new products ideal for your machine Peter!
    To answer your queries so far:
    Drill motors are an ideal budget drive solution, and drop the requirement for an external gearbox as the one provided is perfectly adequate (though in some conditions it may be best to exchange the first stage gears from plastic to metal as used on the second stage). There are also wheels available which will screw directly onto the output shaft of drills shafts and would be ideal for your use.
    The speed controller(s) will often be your most expensive purchase and so making the right choice is paramount. I happen to have a fantastic low-budget solution up my sleeve for the near future so your choice may depends much on what dates youre setting yourself for this build.
    40mhz is the best radio control option. Two or four channels depends much on how you see your designs expand in future and your current budget - it may be worth investing in a four channel model for the future.
    The motors and electronics typically used are pretty well adept to impacts, Ive never personally come across a magnet issue with drills for one thing. It is adviseable to mount electronics with shock absorbing materials such as foam or high-strength velcro.
    Please dont hesitate to ask any further questions!
    _________________________________________________
    Many Thanks, Ewan
