Results 1 to 7 of 7
Thread: Slowing response speed on Victor HV36
    jamez_warner
    Guest
    Anyone know of a way to slow down the response time on a set of victor 36hvs?
    Letting go of the stick just locks the drivetrain up which cant be good for the motor -and going into a turn from moving straight ahead also results in one side locking up straight away...
    James
    The Victor speed controllers will follow the input PWM signal and does not control the acceleration this is usually done in a mixer board connected between the speed controllers and receiver, what kind of mixer board are you using if any?
    jamez_warner
    Guest
    Mixing is done on the TX at the moment, any suggestions of a mixer that would allow it?
    James
    Guest
    Geoff I would look into the regen on victor ! I dont believe they actually regenerate like other speed controllers do. They simply short the motor which runs power back thru the ESC and the energy is turned into heat and the fan cools it, thats why you dont see them in brake mode on spinners, cause theyll self destruct!!! I could be totally wrong on this but I would talk to IFI before trying to regen thru a victor...
    Matt
