Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Electrical problem in new bot
    hi all
    we have decided to make a new robot (my dads) we are using 2 12v drill motors and their batteries. but i wired it all up but it didnt work,
    the batteries were charged, there was voltage at the motors so the spedd controllers are suppling the power for the motors and the rx. but no power seems to be getting to the rx and therefore nothing will work.
    we have checked everything, just used one battery and motor and even tried a SLA, but nothing.
    WHAT TO DO?
    cheers alex
    stu's Avatar
    Member
    What speedos are you using?
    You reliying on the speedo supplying power to your RX or do you have a seperate battery for the RX?
    is the servo wires and (rx battery) connected to the RX the right way round?
    Mr Stu
    Do the speed controllers have BECs (battery eliminator circuits)?
    the ones im using are from tech bots
    and yes the wires are correctly connected
    1500-014/015 Microprocessor Speed Controllers
    Thanks
    have you connected the two wires coming our of the one with the bec(normally orange) together?
  7. I agree with John on this one, the problem is usually something very simple which will be easy to sort but difficult to track down.
    If you are using a BEC from the speedos, did you see if a voltage was coming from it to the receiver?
  8. #9
    hi all and thanks
    the reciever and transmitter im sure isnt faultly because it from Psycho fling.
    im sorry but i havent a clue what BEC is or what is does?
    thanks again alex
  9. #10
    good news
    we have managed to get it working forward,reverse, righ and left. but only with a external battery box for the reciever. can these be used in battles as it has it own switch?
    thanks
