Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Help with Pneumatics
    Guest
    Take a look at the Technobots guide notes - http://www.technobots.co.uk/en-gb/pg_19.htmlhttp://www.technobots.co.uk/en-gb/pg_19.html theres two very good articles about LP and HP pneumatics.
    However, it has to be said, people who dont know what theyre doing shouldnt play with compressed gas (dont think Im being condescending, I include myself in that statement!). Pnaumatics have the capacity to do a lot of damage to humans, so I, personally, avoid them at all costs. If youre not comfortable with pneumatics, theres plenty of weapons you can build without them.
    Hi Woody
    I tried a tescom high pressure high flow solenoid, operating pressure was 3000 psi, however I didnt get the force it was more of a lifter, we have a Valtorc 1/2 full port stainless steel ball valve operated by a pneumatic spring return actuator with a nema 4 24vdc direct mount solenoid. the nema 4 gives us the following torque on the ball valve of 30lb*in at 40 psi upto 37,903lbs*in at 120 psi, the valve was only one way normally closed, the web site is http://www.valtorc.com/pneumatic.htm
    I didnt think of trying a 3 way ball valve, its just clicked now I will be contacting them monday may just change to that. it would save buying another valve.
    Not sure what the speed the valve is but it gives us the desired effect, we tested it out on a dishwasher weighted to 150lb and gained 14 foot of air at 1000 psi.
    The rest of the parts are : 2 x mag 400s 2x Victor 885s, drive system is 4 wheel drive double sprocketed down, runs about 25 mph. 4 battlepack Nicad 3600 ma 24 Vdc batteries in relay, and a double electric switch solenoid for the valve.
    The regulator is a Victor SR4 inlet 4000psi outlet 2000 psi high flow.
    Armour includes 12 x 12 Hardox 3/8ths (AR400) plate on the front of the flipper, 3.1/2 inch 3/8ths Hardox plates down the sides.
    cheers Martin
