Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: Battle bot help needed
  1. #31
  2. agreed with jamess first point. Thwack bots are easy to make and depending on how you have it can be very effective and put on a good show. We use both types for our kits. the normal horizontal hammers for spinning on the spot and then the vertical one which given the correct balence and wheel size, when the machine accelerates forward the bot will flip over stinger style. Quite impressive.
  3. #33
    http://http://robotwars.demon.nl/images/twackbots.jpghttp://http://robotwars.demon.nl/images/twackbots.jpg
    Here is an example of both an horizontal Twackbot, called Bonx, and a vertical one called Debiel. There is a dutch word joke in the latter name, but im not explaining it. The Axe on Debiel works on the idea that you slam the robot from one direction into the other, flipping over the axe.
    (Message edited by leo-rcc on June 10, 2006)
