Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Tech Check question- (for lifters)
    Hi all
    I have recently printed out a tech check sheet from the early thread. And I ahve two questions, it says locking devices and preventing movement of weapon. Would this apply for a lifter?
    Also where it says weaponary tehther insatalled would this part apply to a lifter?
    Hope this is clear
    Alex
    Best use common sense - if the lifter is relatively slow and wouldnt pose much of a threat to humans if it went off for some reason then dont bother about a locking pin because you could end up causing much more damage to your bot if a locked down lifter went off than you could ever cause to people around it. For faster lifters it may be worth looking at putting some safety measures in.
    Tethers almost certainly do not apply.
    ok thanks
  5. Ahem... Geoff?
  7. Fair enough I guess
  8. #9
    kane's Avatar
    Roboteer
    The following is intended to clarify the situation and as this is first and formost a matter of safety it should be regarded as FRA policy.
    Part of FRA build rule 1.5.5. requires that any mechanical device, be it a spinning weapon, a flipper arm, axe shaft, or any other type of mechanism be fitted with an appropriate locking device.
    Whilst I concede that the rule does not use the actual words locking device It is perfectly clear that this is what is required. That is why I posted the UKRG wording as I think it describes very well the intent of rule 1.5.5.
    I am considering, with the permission of UKRG, to incorporate that wording as an amendment to clarify rule 1.5.5.
    In addition I would expect event organisers to include a check of locking devices during the technical inspection of machines competing at their events.
    In short.... If you have any type of mechanical weapon on your robot, it must be capable of being locked to prevent accidental movement!
    Geoff Smith,
    Chairman,
    Fighting Robot Association.
    Kane Aston
    http://www.makerobotics.com
  9. #10
    fully agree, this is one thing though that is rarely policed
