Results 1 to 6 of 6
Thread: Speed problems
    hi everyone
    i wonder whether anyone could help me, i recently replaced a 12v sealed lead battery for two 7.2v nicad ones. but i dont seem to get any improvement in speed from them and they are going even slower than with the sealed lead in. i have worked out it is the batteries or the wiring attached to them because i put back the sealed lead to check and it was wizzing around like it did. so what to do?
    hope this makes sense and someone can help!
    thanks alex}}
  3. stu's Avatar
    Member
    Alex have you wired up your Two 7.2v Batteries in Series mate? This will give you 14.4v which will make it a bit faster than your 12v battery, though not too much difference, just you will save alot of weight.
    Have a quick look here mate - http://www.stupoo2000.pwp.blueyonder.co.uk/teamkat/batteries.htmhttp://www.stupoo2000.pwp.blueyonder.../batteries.htm
    You want to wire your Two 7.2v Battreies the same as the first diagram on that page.
    Mr Stu
  5. thanks for the help
    alex
