Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 109
Thread: Vapourbot Grand Championships 2006
  1. #51
  2. #52
    swiss_tony
    Guest
    Exqueeze me? How does one lift with a crusher? Magic?
  3. #53
    and where did this crusher suddenly come from for that matter?
    quote:
    Positionefence midfielder
    Weight:99kgs
    Dimensions:2X1X2
    Weapons:A bi-rotational axe which spins upward and it has safety cameras to protect the opposition and my own team
    Speed:21MPH
    Drive: 4 S28-400 Magmotors at 36V.
    Armour:Titanium
    Transmission:Chains
    Additionals:Boots on the axe
    no really... where?
  4. #54
    Hades Machine
    Weight: 100kg
    Dimensions: 140x100x60 cm
    Weapons: Lemco motor powered axe (run through gear box) that can deliver an axe blow of 3 tons (according to my calculations) and rear linier actuator operated lifting arm that can flip 600kg
    Srimech: Side arms and rear arm
    Speed: 15mph
    Transmission: a 4 wheeled Tornado set up(36v and same gearing), but with a pair of Mag C40€™s in place of the Bosch motors, and a set of NiMh in place of the heavy Lead Acids the real thing uses.
    Turning Circle: 0m
    Ground clearance: 0 at the scoop and wedge edge, 2mm the rest of the way around
    Wheel Type: Go-kart
    Body Shape: scoop fronted, wedged back
    Armour: 8mm Grade 5 Titanium and 2mm stainless steel
    Colour: Black with flame face on scoop and name in blood writing on side, devil head on rear wedge
    Strengths: Enormous pushing power (About 12hp), EXTREMELY powerful axe, relentless in attacking (until a robot is immobile)
    Weakness: Dislikes spinners, doesnt like weapons that use carbon
    Dimensions: 120cm x 80cm x 40cm
    Weight: 100kg
    Shape: steep wedge front, elongated wedged tail (not used as a weapon)
    Weapon: 1000psi 2 pivot pneumatic flipper that can generate enough momentum and force to throw a 100kg robot 25ft up and 20ft across
    Top speed: 18mph
    Transmission: just like Razer€™s
    GC: 0 at the front, 2mm down the side, 4mm at the back end
    Turning Circle: 0cm
    Armour: 6mm aluminium and steel alloy
    Strengths: Can win with one weapon shot
    Weakness: None
    Notes: 4 wheels, the rear two of which are Razer type, so the flipper is always facing its opponent
    In case youre wondering, the forum wont lt me put H-word on here
  5. #55
  6. #56
    swiss_tony
    Guest
    Yes, what the [-]311?
  7. #57
    http://www.fightingrobots.co.uk/discus/messages/8/5234.html?1142087941http://www.fightingrobots.co.uk/disc...html?114208794 1
    here ya go, some words have been censorised...
    when posting my strategies against I.D.S.F.A, I couldnt even write I.D.S.F.A apostrophe s, cause it would include the a-word
    a serious downfall for team Hades it seems
    (Message edited by MajinB on March 12, 2006)
  8. #58
    swiss_tony
    Guest
    Either change the name to Team Hades or change it to team [-]311? All I got.
  9. #59
  10. #60
    swiss_tony
    Guest
    Cool. Ive been feeling like taking a p- I mean, urine extractionation or something like that..
