Hello all, Ive set myself a budget of £100 a month to build my new bot Work In Progress. Well I thought the name sounded good, if you dont like it then sod ya.
The design is for a 4WD spinner proof wedge shaped rammer. Powered with 4 Golds, controlled by 2 30amp electrolizes and powered with Ni-Cads. Am planning on using 4mm plate for the bulkheads as Ive got a lot of the stuff. Might double it up if needs be and bolt it together with ali angle.
How is this spinner proof? Well the ali holds the bot together and spreads the load. The bot will have inch thick square bar bolted on every six inchs and this will take the spinner blows.
So onto help. Now that Ive moved to London, I need a college where I can work on machining the parts in the evening. In otherwords an engineering non-curriculum based evening course as I went to in Dunstable college.
Failing that some fabrication help at lowish cost. Either from another buider or a machine shop.
Long before that, I need some FREE CAD assistance, anyone know a good GNU licence CAD package. Dont need rendering but 3D is essential.
For the Ni-Cads with 4 Golds what Ah rating am I going for and can anyone suggest a UK supplier apart from technobots if its anything but 3ah.
Any help would be great, looks of help would be even greater :-0
