Page 10 of 21 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 206
Thread: Velociraptor's Fanfic Tournament - Series 7!
  1. #91
  2. #92
    swiss_tony
    Guest
    Doh! Stupid me just realized the rule for SHW walkers is 200 kg. Sorry about that, my bad. Use the 200kg set up instead.
    Light and Middle will hopefully be up soon, as soon as I can get some help [I know next to nothing about otherweights]
  3. #93
    swiss_tony
    Guest
    LW down, just MW to go.
    Name: Dales Dead Bot
    Weight: 25kg
    Power: 4 Cobalt 940 Astros on 24v in NiCads.
    Speed: 14mph
    Shape: Box with a wedge, like Atomic.
    Weapon: A pentumatic set of flipping/crunching spike strips positioned on top of the wedge. They can either go up to flip or go up then down to crunch to do damage, since there are spikes on the bottom as well. Flipping also might damage a little bit. Might self right, might not. Fueled by 2 2kg co2 tanks.
    Invertible: No.
    Armor: 6mm lexan.
    Strengths: Quick, pretty good weaponry
    Weaknesses: Pretty weak armor.
    Unsure if this is overweight or not: If it is, shave off another mm of lexan.
    Oh yeah. Also, a thing I forgot to mention in the stats by accident is that Scarlet Touch, No Stairway to Heaven, and Judo Chop! Are all invertible.
    MW [Waynestock] will be finished ASAP.
  4. #94
    swiss_tony
    Guest
    And heres the MW. Finally done with otherweights!
    Weight: 50kg
    Power: 4 S28-400 Magmotors, 24v in NiCads.
    Weapon: A flipper running on 500 PSI. 2 2kg tanks supply it. The flipper covers the entire front end of the robot.
    Shape: Novastorm minus the bar and lifter, with a flipper on front instead.
    Speed: 16mph
    Armor: 8mm titanium.
    Skirts: Rear and side. 0 at them, 0 at the flipper.
    Srimech: The Flipper.
    Strengths: Powerful flipper, good drive, decent armor.
    Weaknesses: Limited CO2.
    GC: 0 at front thanks to flipper, 0 at sides and rear thanks to the skirts.
    Unsure if this is underweight. Also, Crap, I thought I was forgetting something on Dales Dead Bots stats, the weapon PSI. Say it runs on 250.
    And just Now ive realized Ive forgotten Scarlet Touch and Dales Dead Bots GCs:
    Scarlet Touch: 6mm at sides, 0mm at front and rear hinged wedges.
    Dales Dead Bot: 4 at front, 6 at sides.
    Ill post the slightly modified stats I forgot to place on the FAR forum ASAP so you dont need to go digging for it.
    (Message edited by Swiss_tony on October 21, 2005)
  5. #95
  6. #96
    Okay, Ive come to a realization that I dont really like or want to use The Templar (Ill probably use him in other tournies), and the fact that I didnt know you could use real robots.
    So, for my MW, instead of The Templar, Ill go ahead and use the real robot S.O.B (BB season 5)
    http://www.battlebots.com/meet_the_robots3/meet_robot_specs.asp?id=840
    http://www.battlebots.com/meet_the_r...ecs.asp?id=840
    Some other stats are...
    Ground Clearence at the front is 0mm, sides and back are 3mm.
    The main idea of the robot is to trap it in the dustpan while it hits it with the saw which manuevers on a Servo. The saw is somewhat powerful, and produces sparks that gets the judges attention. The dustpan is also good for getting the opponent to the hazards and pit n stuff like that.
    In Season 5 of Battlebots, it came second.
  7. #97
    swiss_tony
    Guest
    Otherweight stats are up, so no need to go digging into the thread for them:
    http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
  8. #98
    TEAM BRAVEHEART NEWSFLASH!
    Potential new Spin Dash in progress. Stats and picture will be posted up ASAP.
  9. #99
    Im waiting
  10. #100
