Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Summer of Robots tournament.
  1. #11
    Ill enter Back To Rock II
    Name - Back to Rock II
    Shape - A box with a slightly sloped front
    Weight - 100 Kilogram
    Speed - 29 km/h (18mph)
    Dimensions - 90x75x30 cm
    Ground Clearance - 0 at sides (due to skirts) and front, 2 mm at the back
    Power - 2x Etek motors at 48 volt
    Movement - Four wheels, 20cm diameter
    Turning Circle - Zero
    Weaponry - It has a broad hydraulic lifting arm which can easily lift 200 kg. To easily get underneath an opponent, it has two lifting plates at the bottom of the arm, one on the left end and one on the right end, instead of one large lifting plate like Behemoth.
    Between the two plates, in the centre of the scoop, I mounted a vertical diamond edged Pussycat-style blade, powered by a S28-150 Magmotor, spinning upwards at approximately 3000 RPM, which will hopefully rip off some armour, or more likely, a tire, while lifting an opponent. Jamming a blade into an opponent while lifting it hopefully provides as much control over an opponent than a Behemoth-style grabbing claw/axe can, and it€™ll surely do more damage. (To avoid confusion, the blade is actually part of the lifter, so when the lifter moves up, the blade moves along).
    On both sides of the bots is a pair of 5 mm titanium skirts, to make sure I won€™t get flipped very often, as hydraulic srimechs just aren€™t as fast as pnuematic ones.
    Armour - 6 mm titanium all around
    Srimech - The lifter self-rights the robot when needed
    Strenghts - Nice weapon synergy, very high traction, low ground clearance
    Weakness - Hydraulic srimech might prove to be slow
    A picture can be found here: http://jupiter.walagata.com/w/madbull/BacktoRockII.gifhttp://jupiter.walagata.com/w/madbull/BacktoRockII.gif
  2. #12
  3. #13
  4. #14
  5. #15
    hmmm.....kali
    http://www.alexjholt.tkwww.alexjholt.tk
  6. #16
  7. #17
  8. #18
  9. #19
  10. #20
