Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 82
Thread: Spinner Weapon Motor Discussion
  1. #11
  2. #12
  3. John, Our first spinner used the same pancake motors. It had a 2:1 ratio on a 600mm dia disc with the disc weighting only 500 gramms. These motors are very slow compared to an EV or Astro so a big gear ratio would make it run slower, It used a large O-ring for the belt from a car asseccory shop on 2 very deep pullies. We did have one problem with the motor as the shaft is only pressed into the disc armature and it started spinning after only a few test hits. A couple of grub screws fixed this easy enough. On testing we were actually using 240W of power once the disc got to full speed and even more spinning up, so after a fight it was red hot but we never burnt it out.
  4. #17
  5. Im not too sure what range of cars you have in the UK, but over here in Oz, I found a 12v 75watt pancake motor which seems to handle 24v quite nicely. It came out of a Ford Telstar. It weights 750g, 110mm diameter and 40mm tall including shaft(shaft is 8mm double D shaped).
    If your looking for a non-pancake style motor to suit your design better, a Mini EV is a cheap and effective weapon motor. We have one in our featherweight, Vertical Limits, which has a 3.4kg 300mm diameter flywheel which rotates at around 4000rpm. The Mini EV survives a full battle just running of two crappy 2.3amp SLAs in parallel.
    You can buy Mini Evs here: http://www.robotmarketplace.com/marketplace_motorsmisc.htmlhttp://www.robotmarketplace.com/mark...otorsmisc.html
    On that link, check out the HTI motors with 5mm shafts, they might be a half decent motor, but I havent personally used any.
  6. #19
  7. I believe the HTI motors will do quite nice if you run them on 12-14.4v and possibly 18v if you gear the weapon enough and share the load between two motors. Ive seen a few of them smoke at 24v, mainly in Hellbringer X (Aussie Rambot with 4 x HTI motors with SS2 gearboxes on 24v powered by 3600mAh Battlepack)
