Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: IBC repair
  2. stu's Avatar
    Member
    What the hell did you do to it?
    Sent email to you Alistair mate or some people for you to email/contact who maybe able to help you better.
    Mr Stu
  4. You burnt the capacitor and blew the voltage regulator. Seriously, how many amps were you pushing through either?
  6. team_ireland
    Guest
    If you want to get it done professionally go to the repair section on the http://www.robotcombat.comwww.robotcombat.com marketplace
  8. I have LT805CV - That shouldnt matter though probably. Thats some strange failure though... Ive not had anything like it happen to mine in four failures - My guess is something mustve been connected wrongly and if this is your first test run it could even have been a fault on the PCB but I imagine they test the things before sending them out from Australia - but its still worth very carefully checking the PCB for any faults which couldve been there before you first ran the IBC.
    If the motors were simply drawing bucketloads of current the first things to go shouldve been the mosfets (a hint to this lots of toxic smoke ) or the main power track on the PCB which leads to the mosfets on the underside of the board from the positive (+) battery wire. I cant imagine this was the case though running two drills at 18v (what voltage drills were they?) and I cant imagine a battery that small (1200mah) wouldve provided enough current for a current failure in only a very short time.
    Its cost me about £20 each time Ive had to repair my IBC for current failure (the cost just being the price of new components from Farnell or RS components) but youll need completely different components which Id guess would come to around about the same figure (maybe a little more). Its certainly worth sending off to the US to be repaired if you dont have the skills yourself but It costs $135 for a 7 day repair or slightly less for 14 days and then youve got to sort out all the P&P stuff to and from the states whichd add up abit. If youve got the money, sure do just that.
    Im not good at these writing marathons...
  9. #9
    stu's Avatar
    Member
    Ewan this is the same IBC that Ed lent you at XFM Ipswich. So sadly clearly shows the IBC was in a working state before. Though i dunno, god knows what you do to them to have them fail 4 times. You have people like Ploughbot running Astroflights on them, i used to run 4 x 12v drill motors on 24v to the point my batteries were burning the heatshrink away they were pulling so much current, i or ploughbot never blown one up.
    I blame the users
    Mr Stu
  10. #10
    Really, same one? lol, I didnt blow this one up
