Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Electronize Speedos - anyone whos had a problem
    thought id start this thread up, as a few weeks ago i was given a 30 amp ex relay version to fix. after fixing it i thought id fancy some for my self for my feather weight, thinking they where meaty enough at 30 amp continous i loaded each with two drill motors. one controller is now toast.
    relay only turns on for one direction and in that direction if you make it do any work that relay starts chattering, unlike the one i fixed it seems to be the micro.
    im just interested im knowing if many other ppl have had problems in the past.
    im now considering getting some 15amp versions which i think i can mod easily to give greater power output with reliablity - would be interested im knowing ppls thoughts on this mod
    Have you checked for interfearance? If the motor will just go forward with no control- that ushually means the relay has welded itself shut, try giving it a tap with a screwdriver or somthing just to shake it loose- if that doesnt work replace the relay. I had that problem a few times with my old 15amp CPUs.
    Ive got one 30amp exsternal relay- bought from brand new, When i wired it up (correctly) it did nothing- dead, Never got it working- should probably send it back to electronise,
    Any idea what could be wrong with it? Batterys were at full 24v, Motor works- r/c was fine (tested with the other speedo and a servo)
    do the relays click on /off at all , one should always be on at a time.
    with regards to the 15amp speedos im just about to set about designing a booster circuit add on to bring it up to 30- 40 amps
  5. it cost me £10 a controller to get mine overhauled.
  6. #8
