Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Electronics
  1. #11
  2. #12
  3. #15
    team_ireland
    Guest
    Ok Sorry to Hijack this thrend but rather than start a new one.
    I want to build Ian Watts Failsafe system as can be found here:
    http://www.teambigbro.co.uk/failsafe.htmlhttp://www.teambigbro.co.uk/failsafe.html
    What i need to know is, is it possible to make this whole board run on 5v by changing the relay from a 12v coil to a 5v coil. I have looked at the data sheets for the Flip-Flop, The 555 Timer, the FET and the Transistor and all appear to work down to 5 volts.
    So can anyone verify this?
    Thanks
    Regards
    Ian.
  4. #16
    kane's Avatar
    Roboteer
    Should be fine... You may need to substitute the FET for a transistor on the output if it doesnt work.
    Please note you will get a better response if you start your own thread in the future.
    (Message edited by Kane on December 08, 2005)
    Kane Aston
    http://www.makerobotics.com
  5. #17
    I dont see anything that wouldnt work at 5V but I would double check the timing doesnt alter otherwise it wont work as expected. Also it will be very sensitive so make sure you have a good Rx signal. The ones Ive used in PICs filters the Rx signal such that one off errors will not trigger the failsafe and infact it needs 10% pulse errors within any 2.5 seconds period before it will failsafe. Even this has false triggers in our robots every now and then for the robots that dont use PCM.
  6. #18
    kane's Avatar
    Roboteer
    Just spotted on the site that Ian says:
    Specifications
    The maximum input Voltage is limited by the 555 chip to 15 Volts
    The minimum input voltage is 5 Volts
    Kane Aston
