Forget the IBC and the Vantec. Heres a speedo which should suit anything from 12-50kg!
(taken with permission from the RFL forum) -
Hi All,
After nearly two years of development Robot Power is proud to announce the general availability of our newest motor control...
Sidewinder
Here are some of the specs on this exciting new controller:
* Dual channel 80A continuous each
* 150A+ peak each channel
* 14V to 50V voltage range - 36V maximum recommended
* Tough extruded Aluminum case enclosed against dust and chips
* 16 MOSFETs bolted to massive 0.5 thick heatsink bars in turn bolted to enclosure for extra heat dissipation
* Integrated R/C interface with 3-ch inputs (Left, Right, Flip)
* Adjustable active current limiting (10A - 130A)
* Adjustable command slew rate
* Fixed over temp protection each channel
* Solder or bolt mount high-current leads
* The software features you expect; mixing, tank-mode, mirror mode, R/C or gravity Flip input.
* Three indicator LEDs visible from outside the case (left/right motor speed direction, status)
* Remote on-off switch
* Utility 12V output for power-on LED or other uses
* Size: 3.2 x 4.3 and just 1.1 high!
* Weight: 335g (12oz) without optional mounting brackets or power wires
* Price: $325
Under development is an on-board 2.4GHz radio transceiver and a single axis gyro that fits inside the enclosure.
Note, the Sidewinder is not in volume production yet. We are building them by hand on order for now. There may be a week or more delay in shipping your Sidewinder so we cant promise last minute gratification of your speed controller needs. Well let you know when we get the machine assembly process going and resellers have stock.
*Ewans edit - I have combined four pictures of the unit in a large picture on my profile*
Chris Baron
chris@robot-power.com
Team HAWG
(oo)___/
WW WW
Best Regards, Ewan
